Removing old and fi...
[Closed] Removing old and fitting new headset advice pls.
The bike is an Orange Crush 2018 in case it helps.
1. Do I really need the proper (rocket) tool to remove the old headset cups or is drifting them acceptable ?
2. Can I use any generic bearing press ie. The one I use for BBs to press the new ones in ?
Thanks in advance.
Posted : 11/09/2021 6:42 pm
FWIW I got mine out by using a socket extension but it was a bit awkward and they couldn't be used again. I bought a cheap tool for inserting the new ones and it was a PITA and I damaged the surface of one of them. I replaced it and bought the correct tool for putting the new ones in second time around and it was a complete doddle... If you have a tool for the BB and it fits then that will most likely work fine..
Posted : 11/09/2021 7:05 pm
 Yak
1 - no/yes, go steady.
2 - Any press will do if the drifts fit. I am the other way round and use a headset press to press in bbs as they fit.
tbh - on a hardcore alu frame, a block of wood and hammer will get it in just fine if you are careful.
Posted : 11/09/2021 7:07 pm
Thanks both.
Posted : 11/09/2021 7:10 pm
Why remove the cups, just pop new bearings in, or are they loose ball and the races goosed?
Posted : 11/09/2021 7:11 pm
The top head race bearing is caged ball and I thought that one with a sealed bearing unit would require less looking after.
Wrong thinking ?
Posted : 11/09/2021 7:36 pm
If it's the top cup I'd leave as is and just maintain the top. I always find I get two properly knackered lower cartridge bearings to one tired upper cartridge bearing.
Posted : 11/09/2021 7:41 pm
Big screw driver plus hammer to remove.
Large lumps of wood and a hammer to refit.
NB, I'm not a professional bike mechanic!
Posted : 11/09/2021 8:03 pm
Rocket is a revelation. Yes you can make your own, if you have a decent bit of pipe go for it.
Press is a doddle as well, I got a Brand X one with a proper bearing on it. Brilliant.
Yes you can bodge it but using the proper tool is quicker, easier and less prone to ham fisted buffoonery.
Posted : 12/09/2021 12:42 am
I use a bench vice for fitting, much straighter than block of wood and hammer. Do one cup then the other, don't do both at once
Posted : 12/09/2021 12:52 am
Thanks all.
The replacement headset was bought, so I may as well fit it. I have now bought a Unior rocket tool  (£20) for cup removal, as it might allow the re-use of the cups if required at a later date and might fit my OHs Shimano pressfit BB, if it ever needs replacing. Will see if I can use my wheels manufacturing press with some BB fittings to install the cups
Posted : 12/09/2021 5:54 pm
