removing handlebar ...
[Closed] removing handlebar grips.
what is the best way to remove handlebar grips? thank you for any replies.
Posted : 07/04/2012 7:32 pm
GT85 for me
Posted : 07/04/2012 7:36 pm
Hairspray. Acts as a lubricant when you first spray it...and sticks when you slip them back on. Or if you haven;t got any I find deodorant works.
If you plan on using the grips again, I wouldn't recommend using any lubricants.
Posted : 07/04/2012 7:44 pm
gt85 if just fine for putting them back on again, it goes off and sticks - try it sometime
Posted : 07/04/2012 7:46 pm
I spray wd40 under the grip using the straw attachment you can clip into the nozzle. And then pull - hard!
Posted : 07/04/2012 8:12 pm
GT85 or WD40 with a straw, then a good wash in shampoo and hot water and allow to dry.
Or a blast of compressed air under the grip and hold on tight, because the grip will fly!!!
Posted : 07/04/2012 8:18 pm
I undo the screws at each end. Works a treat and no problems re-usng them.
Posted : 07/04/2012 8:19 pm
Hairspray for me
Posted : 07/04/2012 8:22 pm
Get something in between the bar and grip and squeeze in some Fairy liquid to remove. Works really well once you've manipulated the grip to get the liquid all the way around / in.
Spray hairspray into the grips before replacing for the magical lubricant becomes glue effect...
Posted : 07/04/2012 8:26 pm
ok thank you all who replied.
Posted : 07/04/2012 10:45 pm
