Removing display on...
[Closed] Removing display on deore shifter
Does anyone know if this is possible? I know it is on XT and XTR but unfortunately i dont have the money to upgrade.
Posted : 30/06/2010 12:13 pm
Posted : 30/06/2010 12:15 pm
Yeah, take the shifter off, unscrew the display, at the back of it there is a little disc, place that on the hole the display has made, use the screws you just gained and fit them.
Does depend on what year it is though.
Posted : 30/06/2010 12:22 pm
 xcgb
Why would you want to?
Not offical, as per SLX,XT and XTR, your just left with thomthumb's suggestion,
EccentricEllis - you can't do that on Deore.
I thought XTR came without windows anyway? Mine did.
I took them off my XT as well - I never use them and it's just one more thign to break/clutter the bars up.
Posted : 30/06/2010 12:26 pm
to let you get the brake lever/ gear lever set up sensible.
never been able to get any shifter with a window to work properly with my brakes!
I want to remove it so that i can fit my new hope brakes and have a comfortable setup.
It is payday today so i might have to put off paying a bill or two and get some new shifters.
Posted : 30/06/2010 12:30 pm
 br
You can do it on SLX, otherwise its a bodge.
Posted : 30/06/2010 12:39 pm
+1 Tomthumb, it's not going to look very pretty though and the pastic doesn't look like it'll cut well.
I upgraded instead.
Sell your Deore for £20 and buy SLX for £30ish.
Posted : 30/06/2010 12:42 pm
I did it on my old XT's with gaffa tape for years and years before shimmy caught on and started doign it properly with blankling discs etc. Just cut some old innertube into circles to pop in the top of the shifter, then gaffa over the top. Nice sticky gaffa that dosn't come off, otherwise you'll get grit in the shifter mechanism and all the funny tards that suggest you leave the windows on will laugh at you.
Works fine though. No stupid windows to tell you which gear you already know you're in.
Posted : 30/06/2010 12:45 pm
I've done some deore ones recently, used some cable cutters on the plastic, then tape to seal.
Does it work? No problems so far.
Does it look ugly? Yes if you look at it, but it's under the bars/brakes so you'd have to actively go hunting.
In summary:
Do it.
Posted : 30/06/2010 1:06 pm
how easy is it to remove the window from xt shifters? is it really really really that simple even a moron like moi could do it?
Posted : 30/06/2010 1:26 pm
you have to undo a small screw(s), remove the window, put the blanker back and then do them back up again.
people can **** anything up so saying 'you'll be fine' is maybe a bit optimistic...
Posted : 30/06/2010 1:46 pm
