removing decals
[Closed] removing decals
Got some new decals, whats the best thing to use to remove old ones?
Posted : 25/06/2013 7:48 am
Not sure on your frame but on my old BMX frames i just pull them off and use WD40 to clean off the old sticky residue
Posted : 25/06/2013 7:55 am
it's a ti frame, and they don't want to be pulled off?
Posted : 25/06/2013 8:02 am
Warm them with a hairdryer, remove any sticky residue with brake cleaner. Never tried brake cleaner on Ti frame but WD40 would work but you'd then need to degrease before applying new ones.
Posted : 25/06/2013 8:04 am
 aP
Razor blade.
Posted : 25/06/2013 8:14 am
Acetone (nail varnish remover) will soften them enough that they can be rubbed off with a cloth.
Posted : 25/06/2013 8:15 am
What scotroutes says.
Although only use if the frame has a raw finish and does not have a painted finish - it will remove the paint/powder coat also!!
Anodized finish is ok - obviously it won't be an anodized finish on a Ti frame.
Posted : 25/06/2013 8:34 am
Hairdryer + WD40 or soap & water
Posted : 25/06/2013 8:55 am
Thanks guys, i'll be raiding the other half's cupboard!
Posted : 25/06/2013 9:19 am
