Just knocked my Sigg bottle off the bench and put a big dent in it.
Any ideas on how to remove/reduce it.
A socket extension bar in through the neck and push the dent out as best you can.
I was going to suggest a stick, but stoners Ida would be better.
Don't. They look way better with dents in. They are [i]supposed[/i] to have dents in.
Local body shop (not the cosmetics)
Don't fill it with water and freeze it.
Drill a hole and pull it out. ๐ก
Buy a new one cheapskate!
Industrial compressor. As an aside, I have one with a huge dent from a memorable fall off the wet woodwork at Chopwell. Went all fuzzy for a few minutes.
Put a small amount of water in it, screw the lid on and then stand it on a stove. The tricky bit will be removing it from the stove after the steam pressure has pushed out the dent but before it explodes.
They are supposed to have dents in.
This
My brother froze his. Worked fine for one of them, turned the other one into a pretty awesome Sigg rugby ball.
If the dent was from something EPIC and memorable aye it would look good but I jusr knocked it off my work bench and it landed on a bit of wood.
Dent free Sigg bottles just look wrong.
I'm sure you're mistaken about how it acquired the dent. Surely you were doing a mahoosive drop off when you crashed and the botte was in your backpack at the time!!
you will breach the internal liner if you do anything dramatic. unless it's reduced capacity by 50% I'd leave it.
