Removing a lower cr...
[Closed] Removing a lower crown race.
Not a major problem, done loads. Though this baby is well snug against the carbon crown and steerer.
Any tips?
Posted : 02/12/2010 8:09 pm
They've got a 'Black Box' crown. Absolutely zero gap for a blade and very bulky. Anyone tried a crown removal tool?
Posted : 02/12/2010 9:44 pm
I'd prob use one of these given the carbon ๐Ÿ™‚ They are supposed to be good ๐Ÿ™‚ However I'd take it to LBS and use theirs it might be cheaper?
Posted : 02/12/2010 9:48 pm
For a carbon crown/steerer i would get a shop to do it.
stanley knife blade hammered in the gap very carefully? Thats what I do with stubborn metal ones but dunno about doing it on CF
You'd not get a razor blade in these.
Posted : 02/12/2010 9:50 pm
I use a wood chisel on metal ones, could be worth a try...
Though I'd give it very little pressure from the hammer to chisel technique.
Posted : 02/12/2010 10:17 pm
Park crown race removal tool, any decent shop should have one. I had a trek full carbon road fork to do the other day and was very glad to have that bit of kit.
Posted : 02/12/2010 10:19 pm
That's just not gonna happen with these. The bottom of the race is sat absolutely flat on the crown. And because the carbon crown is so bulky there isn't a single point to get leverage.
Split races rule, well they will when this ones off.
Posted : 02/12/2010 10:20 pm
I was hoping mike might come along, as he removed one from some SID World Cups.
Posted : 02/12/2010 10:21 pm
Cheers Pete I'll have to use one, I don't think I have a choice.
Posted : 02/12/2010 10:22 pm
I'd recommend using a large baseball bat, not for the crown race removal, but for beating the clown that designed it,why in God's name would anybody design a crown race with a square edge that prevents any removal tools being fitted/used?
Posted : 03/12/2010 9:51 am
Cut the crown race with a dremmel? Then you have a nice split race as well.
Posted : 03/12/2010 10:37 am
No joy yet. The crown is so bulky and the race sits so flush. Might contact Rockshox.
Posted : 03/12/2010 10:28 pm
+1 for nice sharp chisel, flat side down
maybe heat it up first to make it shift with less force ?
Posted : 03/12/2010 10:44 pm
I think I'd just use the same type of headset that uses that crown race.
Posted : 03/12/2010 11:31 pm
