Rejoining a split c...
[Closed] Rejoining a split chain
Pushed the connecting pin out to split the chain to degrease it properly. It should go back in cleanly but would you do that or put a split link in instead? I’ll do whatever is likely to be the strongest...
Posted : 05/02/2020 9:37 pm
Split link
Posted : 05/02/2020 9:41 pm
Modern chains don't seem to go back together very well. I always used to push the pin back in but these days I go for a split link
Posted : 05/02/2020 9:44 pm
Definitely split link, especially if you want to be able to remove it again in the future to clean it.
Posted : 06/02/2020 12:31 am
+1 Split link every time.
Posted : 06/02/2020 8:51 am
I have had 2 mechanicals resulting in me walking home in the last 2 years (last one 2 weeks ago). Both were due to chain snapping and both chains had been split and rejoined with a chain tool numerous times (due to change of ratios on fixed gear bike)
I am never going to rejoin a chain again and am now intent on keeping same gearing for life of chain...
Posted : 06/02/2020 8:59 am
I used to split and rejoin my shimano chains multiple times until i realised that you shouldn't do it. I use split links now - and i re-use them multiple times as well...
Posted : 06/02/2020 11:43 am
8 & 9 speed chains were fine rejoined with the pin (except Shimano). Now, its best to use a split link.
Posted : 06/02/2020 11:48 am
I am never going to rejoin a chain again and am now intent on keeping same gearing for life of chain…
Simple solution to that is to use the spare chain when you get a new one to make up a set of extensions. Then put two quick links in the chain next to each other in the shortest ratio you'll run. Track ends should give enough adjustment for about 4-5t difference so if setup correctly you need extensions about 3/6/9 half links long (i.e. 1.5", 3", 4.5").
OTOH, I've never broken a track chain when I have had to join it without a link. The thicker side plates seem much more resilient to bodging, and they're not being twisted.
Posted : 06/02/2020 11:53 am
Another for a quick link...  chain pins are not designed to be driven out and then used to rejoin
Posted : 07/02/2020 4:57 pm
I do as thisisnotspoon, I'll run a short chain with a section of 3 links with two pairs of quicklinks. If I change to a smaller sprocket I take out the 3 links and put in a 2 link section instead.
Posted : 07/02/2020 10:18 pm
