Very tempted by the new MPR Coil Ribbon forks but they only come in Boost. I have found a set of woolftooth componant adapters for my pro4 front hub. BUT i will need the wheel re dished.
Is this a simple job for my LBS or will it require new spokes etc.
And yep they are closed today as i did try to ask them first 🙂
Dishing doesn't have a huge impact on spoke length. For example moving the rim 10mm will result spokes needing to be around 1mm longer on one side and 1mm shorter on the other. Using your existing spokes should be fine. Its actually a pretty easy DIY job and will be simple for an LBS if you really don't want to do it.
Ace, thanks nick.
hope also do the adaptors.. but they still require the wheel to be redished
