recommend me an off...
[Closed] recommend me an offroad tyre 700x32c max for my specialized diverge smartweld
hi guys i'm looking to make my diverge dsw drophandle a little more offroad robust, i managed to rattle out some spokes on it earlier this year on cobbles. i'll be riding canal towpath, woodland, bridleway, uphill rough tech, and 60-70% road farm tracks.
whats the recommendations, my max tyre clearance is 32 (maybe 33), i fancied some schwalbe g-one style but they are too wide.
i want fast rolling, grippy and puncture proof (possibly attempt tubeless)
options appear to be
spec trigger sport 700x33c £23
conti cycloX-king 700x32 £34
conti mountain king cx 700x32 £44
kenda smal block8 £26
kenda happy medium 700x32c
or a schwalbe cxcomp 700x30c
can anyone recommend any
Posted : 14/09/2017 10:19 am
spec trigger is an excellent choice - if it suits great fro gravel and dry but it'll be awful on wet mud/ grass. (at least on the front)
small block 8 never seems asd fast as you'd expect.
I'd add halo twin rail to the list - never ridden one but keen to.
Posted : 14/09/2017 10:22 am
panaracer gravel king SK 700x32
edit: although I don't think that size is officially tubeless.
Posted : 14/09/2017 10:23 am
G-One 700x30 should fit, those 32c panaracer Gravel Kings SKs apparently will be ~35mm bead to bead.
Posted : 14/09/2017 10:39 am
I'm running a kenda happy medium 700x32c on thereat of my Grade, Can't get it to go up tubeless though. No punctures as yet. Grippy but not really draggy on the road.
Posted : 14/09/2017 10:53 am
The only one on your list that I've tried is the Conti X-King. I'd rate them. I ran them at 32c for a while and they were suprisingly fast rolling on the road and very grippy off road. I switched to WTB Nano 40c just because everyone rated them and my frame could take them.
Posted : 14/09/2017 11:03 am
thanks guys, i cant find that g-one allround in a 700x30c for sale on uk sites is a 700x32c a 28x1.2
that happy medium looks a good one, I'll avoid the spec triger then, the roads and mud is always wet in yorkshire
Posted : 14/09/2017 11:04 am
I've got G-One 35's fitted on Pacentil SL25 rims to my Diverge Smartweld at the moment- 34mm actual width- there's about 4mm clearance each side on the chain stays, obv. more at the seat stays and forks.
With true wheels they're fine even when it's wet/sloppy/gravelly - until mud and clay start gathering, but that's not really the Diverge's territory.
Last winter I ran WTB Crosswolf's, 32's, more clearance, loads of grip, but still had issues at times with clagging up.
EDIT: As you might have already found out, the 700x30 G-One is labeleled 'G-One Speed' - it's a rebranding of last years S-One road tyre.
Posted : 14/09/2017 11:24 am
Posted : 14/09/2017 11:37 am
I rate my SB8s but have nothing to compare them to, as I've stuck wit them for a few years on the arkose.
Posted : 14/09/2017 12:00 pm
thanks vinnyeh, my wheels are true so i may try the g-one 35s,
i'm currently just on a turbo due to injury,
long term ideally i'm wanting a new wheelset for offroad, i'm pondering a few cyclocross events and use the current wheels for the road.
did you find it easy to get a second pair of wheels that fit the current mech hanger on the diverge SGS chainstay seems a problem if you want to use standard wheels and an alternate pair
Posted : 14/09/2017 12:09 pm
just found this i'll save for reference aswell
http://singletrackworld.com/forum/topic/find-me-a-tyre-700x32mm-or-35mm-winter-road-the-odd-muddy-track
Posted : 14/09/2017 12:12 pm
Diverge Smartweld isn't an SCS frame, it just uses a kinked hanger to allow it to use SCS wheels.
Specialized make the Lucky Callahanger Long, which is all you need to run regular wheels on the frame.
[url= https://nextcycling.com/blog/2016/11/16/scs-faq ]Here's a good blog post[/url] explaining the mess that Specialised created with SCS.
Posted : 14/09/2017 12:44 pm
@vinnyyeh to run two sets of wheels is it possible to run the axis wheel (sgs) and another brand of disc wheel using the same hanger.
Posted : 14/09/2017 1:41 pm
Not if you want to be able to shift right across the block.
Posted : 14/09/2017 2:27 pm
so i need to keep an eye on ebay for identical wheels or get a set made up, lbs quoted me £400 a few months back :0(
Posted : 14/09/2017 5:10 pm
