Recommend me a Meri...
[Closed] Recommend me a Merino Baselayer
Merino wicks very well (I haven't seen figures comparing it directly, but I seem to recall that density of weave and fineness of fibre made more difference than wool v synthetic). I was careful to swap like-for-like when going from capilene to merino.
Actually that's a fundamental misunderstanding of the way merino works - it doesn't wick particularly well in the sense of moving moisture outwards away from the skin, which is what most wicking synthetics do, unsually using the structure of the fabric to do it. What it does do really well is absorb moisture and hold it away from the skin so the fabric still feels comfortable even when it's slightly damp. It's also brilliant for not smelling with repeated use and for comfort against the skin.
If you're really sweaty, you're probably better off with a thin, high-wicking polyester baselayer fabric that will move moisture outwards fast and dry a lot more quickly.
Merino's also less robust than synthetics and prone to be eaten by moths - generally when it's unwashed though, if it's clean they apparently don't find it quite so more-ish...
Icebreaker or Smartwool for me fwiw.
Posted : 06/10/2010 11:38 am
Another fan of IceBreakers here...having being completely submerged in very cold water on a day when the temperature did not exceed 3 degrees celsius I can vouch for the fact that they do, in fact, keep you warm when wet through!
Posted : 06/10/2010 11:48 am
 sas
Finisterre of Howies. They're light enough that you can pack an extra one in case it's too cold.
Posted : 06/10/2010 12:28 pm
"If you're really sweaty, you're probably better off with a thin, high-wicking polyester baselayer fabric that will move moisture outwards fast and dry a lot more quickly. "
indeed, that is my point.
The effects of merino on my wife were exactly like cotton - it was wet and she got cold - end of story. Never happened with the synthetic tops she wore before.
If you're soaked through and cold when wearing Buffalo DP clothing you have to do a brief burst of exercise to raise your skin temperature which then drives the moisture outwards, leaving the skin feeling pretty dry and certainly warm and allowing the insulation to do its stuff. I imagine merino works the same way - if your skin temperature drops too low the moisture in the fabric can end up sitting against the skin, thus causing chilling.
I came quite close to buying another merino top - one got killed by a hot wash, another gradually shrunk despite wool cycle washing - but realised I'll probably have another laundry disaster so picked up a Capilene 3 half-price instead.
Posted : 06/10/2010 1:04 pm
Worth looking here: http://www.actionoutdoors.co.uk/shop/base-layers-thermals-icebreaker-c-6858_7449_7669.html some good offers
Posted : 06/10/2010 1:10 pm
BadlyWiredDog - probably off-topic. But this is interesting to me.
Yep, I know about that aspect of wool. But I was referring to the overall ability to transfer moisture from skin to air (or skin to next layer). I.e. ignoring the fact that they can retain a high proportion of moisture. It's still interesting to know how quickly it can be got rid of compared to synthetic. It would be no good if all the moisture just went to the core - we'd be wringing them out every hour!
A quick search still didn't bring any direct comparison though.
Posted : 06/10/2010 1:11 pm
One thing about Merino is there are a mahoosive array of 'types' that is, weave, grade etc which all affect the ability for it to 'dry'. IB use a different grade to our stuff these days, we got a specific turbo merino made which dries way quicker for the very reason that it works better for 'active' sports where you will sweat a lot. Its this drying speed, to me, that defines whats going to work and not work so well. While IB stuff is nice its also, in my personal opinion, not of the quality it used to be. We've been doing a lot of work on weaving sensors into the actual merino fibre itself (for future bio-sensory garments) and its been quite interesting getting hold of merino here - IB buy it all.
Posted : 07/10/2010 9:11 pm
Page 2 / 2
