Recommend a saddle ...
[Closed] Recommend a saddle pack please
7 Users
I've got an old and well used Wildcat Gear Tiger harness. This does the job, but its a right faff to remove stuff and pack down smaller or vice versa - its got a separate dry bag inside the harness but you then have to tighten/loosen all the retaining straps.
Im looking for something simpler which I can just pull clothing out of, cinch down easily and get on with riding - or stuff layers back in if I warm up.
Any suggestions? Needs to be able to hold a down jacket, spare base layer, jersey and maybe even a few other bits for bikepacking occasionally.
Posted : 29/10/2021 4:02 pm
Ortlieb would be my first thought.
Posted : 29/10/2021 4:31 pm
When I looked, apidura were the lightest fully waterproof all-in-one saddlebags.
Posted : 29/10/2021 6:18 pm
Get waterproof not water resistant. Probably narrows it down a fair bit and hikes the price, but makes total sense as it's directly in the firing line of your rear wheel spray.
Posted : 29/10/2021 6:35 pm
Cheaper - Lomo or Alpkit
Not as cheap - Orlieb, Apidura or Revelate.
Other option for actual bikepacking - I prefer to use the seatpack for sleeping gear that goes in and stays put, use a bar bag/roll that's easier to access for clothing. For that way of doing things the Wildcat seat pack system is hard to beat.
Posted : 29/10/2021 7:29 pm
Revelate Spinelock.
Waterproof. bombproof and does not swing about. The large is massive, get the smaller one.
Available from Backcountry.Scot
Posted : 29/10/2021 7:34 pm
Depending on where you are going don't rely on any bag being waterproof. Always put your stuff in a dry sack inside the bag no matter how good the brand is.......unless perhaps its an ortlieb.
Posted : 30/10/2021 10:02 am
