Red Spokey
Park or a Madison Spokey. Nothing else worth looking at.
+1 for park
I'm a Spokey fan too, I can work with them quicker than anything else.
[url] http://www.cyclesportsuk.co.uk/product_info.php?products_id=1068 [/url]
Park is the dogs doodars.
i've got the triangle park one - doesn't slip but kills your fingers - no good for wheel building
Spokey key here too
Cheers guys. Will give the red one a pop.
Ive had one of these since i did my training, solid and dependable with a 4 sided grip
[url= http://www.webbline.co.uk/default.asp?pID=11 ]Clicky[/url]
Cant say ive ever been a fan of the spokey ones, or the park professional ones ive tried them both and have always gone back to the one in the link above.
If you buy a Spokey,try and get the Pro version as it has a deeper jaw and is less likely to slip or damage nipples.
So does, Topeak Alien soke key (wreck nipples) where can I can the pro spokey?
dt spokes - red spokey pro
standard spokes - yellow spokey pro
red and yellow spokeys in the garage tool box, all-in-one BBB tool in the camelbak, similar to this but think my is ally not cromo
http://www.ukbikesdepot.com/products.php?plid=m11b0s72p1334
comfy enough to use to build a full wheel, and should fit any wheel in my riding group if needs be.
You can have a real fancy one with a red cross in it for £14
http://www.chainreactioncycles.com/Models.aspx?ModelID=31322
[img]
[/img]
Or one with a hole in it for £5
http://www.chainreactioncycles.com/Models.aspx?ModelID=19098
[img]
[/img]
I guess the cross was hand carved or something? 😉
Cheers, but I want the red spokey pro - where from?
ta
I have a Park, its very good
One with a hole - cheers!
Now where can I but DT spokes - can't find them on CRC?
ta
The one in the top pic makes a crap spokey but is good for removable tubeless valve cores.
Black Park Pro here. The four sided designs I find a bit of a pain as you have to slide them over the top of the nipple rather than from the side which takes more time.
Best spoke key i have ever tried after exploding a spokey:
[url= http://superstar.tibolts.co.uk/product_info.php?cPath=36&products_id=100 ]P&K Lie spoke key[/url]
made in germany, so not cheap!
yellow spokey for just about everything
red spokey for just about everything else
swearing and molgrips for other sizes
