Rear wheel resistan...
Rear wheel resistance when axle is tightened
Hi
I have a new wheelset on a Superstar components V6 hubs. First time fitting them.
Aving an issue with the rear wheel. Everything ws working fine with the previous wheelset - hunts - and still work fine when i refit them so it's something to do with the Superstar wheels.
The wheel rotates freely as expected with the axle done up lightly finger tight.
If I apply any more torque there is a lot of resistance. I cam turn the wheel by hand but it is very tight.
Any ideas?
Posted : 11/09/2022 11:41 am
Sounds like the bearings are getting overloaded, maybe they aren’t seated correctly.
Warranty job I guess in case you mess them up.
I’d probably take off the free hub and have a nose around anyway in case it’s something simple.
Posted : 11/09/2022 12:14 pm
Could be any number of things.
Have you tried removing the brake caliper to rule out pad/rotor alignment?
Is there a space between the cassette lockring and the drive-side dropout?
Posted : 11/09/2022 12:26 pm
There’s possibly a shim missing somewhere, maybe between the freehub and the hub bearing, or between the end cap and the outer hub bearing?
Posted : 11/09/2022 12:56 pm
I'll test fit them again and check what's been suggested.
And get in touch with superstar Monday if there's no solution.
Thanks again.
Posted : 11/09/2022 3:06 pm
Has this with a Novatec cxd wheelset I bought off eBay.In my case it was a quick fix,the DS wheel bearing hadn’t been fully seated and a quick turn of a bearing press sorted it.The stiffness was caused by the freehub touching the bearing.
Posted : 11/09/2022 3:40 pm
Removed caliper and checked for rub on the cassette.
I'll get in touch with superstar tomorrow. Don't want to go prodding when it may be a warranty issue.
Posted : 11/09/2022 9:14 pm
