Rear lights for a t...
[Closed] Rear lights for a trail bike with a Reverb?
I'm after some suggestions for one or two decent rear lights that I can mount on my FS bike. Its a suspension frame with a Reverb, so there's no real seat tube or seat post to mount on.
A pair of lights fitted to both seat stays would work well - but they have to be very angled so that they face backwards, not up into the sky.
I did wonder about a pair of the 'fibre flare' things up the seat stays but they are not cheap, maybe there is something more suitable.
Any suggestions?
Posted : 11/09/2017 8:54 pm
normal light on the seatstay.
or on your pack?
Posted : 11/09/2017 8:55 pm
Is there none of your reverb post showing?.
Posted : 11/09/2017 8:56 pm
saddle rail mounted light, like this...
https://www.merlincycles.com/moon-comet-x-pro-rechargeable-rear-light-93618.html
Posted : 11/09/2017 8:57 pm
I've found most lights to be adjustable enough, thanks to the bracket, that it should work fine on the seatstay (like the 2AAA style ones)
Posted : 11/09/2017 9:22 pm
For riding on the road? I have a light on my camelback.
Not on the trail though, unless you want to annoy the rider behind?
Posted : 11/09/2017 9:27 pm
That Moon Comet looks good.
As for mounting on bag, I don't tend to ride with one on short rides.
Theres barely 5mm of seatpost showing as its pretty slammed in the frame. for use on road and off, as most local rides are a bit of a mix.
Cheers all.
Posted : 11/09/2017 9:47 pm
 Crag
I've got an Exposure Flare fitted to the seat rails. Great light.
Posted : 11/09/2017 10:38 pm
These are cracking little lights with a wide angle of illumination and come with 3 sizes of O-ring type clamps, the smallest of which is perfect to secure them onto the seatstays.
[url= https://www.planetx.co.uk/i/q/LIDOLR200R/dosun-line-lr200-rear-light ]Dosun Line LR200[/url]
Posted : 11/09/2017 10:48 pm
I had the same predicament with a reverb that was fully in the seat tube, and the position of the top tube joint was just below this which meant I couldn't clamp it to the frame. I used one of the very neat little Lezyne ones - it wraps around the collar of the reverb just perfect. If your seatpost is very short the light may be hidden behind the top of the rear tyre but for a trail bike you should be O.K.
Posted : 11/09/2017 11:01 pm
Can 2nd the moon comet... I have 2 which are both mounted to a bracket that fixes to the seat rails.
Very bright too
Posted : 12/09/2017 5:45 am
Lezyne Strip Drive? fits nicely on the seat stay(s).
Posted : 12/09/2017 8:43 am
I also have one of those Moon Comets chakaping linked too. Had it for a couple of yrs now and very pleased with it.
Posted : 12/09/2017 9:28 am
If you always wear a helmet, maybe one there?
Posted : 12/09/2017 10:27 am
I 3D printed a mount that fits around the seatpost and accepts any 'belt clip' style light.
If anyone wants one printed let me know.
Not this one, this was one I made for a 27.2 seatpost to hold a magicshine lamp horizontally, but used a similar design. The material is like a stiff rubber so no need for screws/clamps. And I've got the surface finish a bit smoother since then too (I wasn't running the extruder anywhere near hot enough).
[url= https://farm5.staticflickr.com/4346/36624220242_6331a7a681_c.jp g" target="_blank">https://farm5.staticflickr.com/4346/36624220242_6331a7a681_c.jp g"/> [/img][/url][url= https://flic.kr/p/XNmGH9 ]2017-08-25_01-24-31[/url] by [url= https://www.flickr.com/photos/7614571@N05/ ]thisisnotaspoon[/url], on Flickr
Posted : 12/09/2017 11:45 am
I've got an Aldi copy of the Moon light. It originally came with a bracket that fitted to the seat rails, but that broke. However, it also came with a rubber 'watchstrap' style fitting that sits really securely on my Reverb's collar.
Works really well, especially as I don't have very great seatstays on my Four!
Posted : 12/09/2017 11:50 am
Rear of bike helmet, slung under saddle rails, wrapped round collar of reverb, wrapped round seat tube, on back of backpack/bumbag/jacket...
Plenty places to fit lights, just need to find a light with a suitable mount.
Posted : 12/09/2017 12:02 pm
I just tend to buy a job-lot of the On One strap on lights (whichever are going cheap - skull shaped, plain, whatever).
They can pretty much be bodged onto wherever, last a reasonable amount of time, and often cost as little as £0.99 each if on offer.
Actually, currently £0.99 each(!)
[url= https://www.on-one.co.uk/i/q/LIPHSOFL/phaart-strap-on-led-light ]https://www.on-one.co.uk/i/q/LIPHSOFL/phaart-strap-on-led-light[/url]
Posted : 12/09/2017 12:42 pm
