Rear derailleur not...
[Closed] Rear derailleur not keeping chain tight
4 Users
I’m running an 11 speed XTR M9000 with standard XTR m9001 Cassette, all been fine but today the chain was very slack even with the clutch engaged, visibly hanging down.
I suspect that the clutch has failed?, any other suggestions?
Posted : 30/03/2019 5:35 pm
Most likely a clutch failure. Just had it happen with my XTR, same symptom. You can buy the clutch kit. I took mine to the shop to have them do it as I'm a mechanical retard, and the clutch replacement cost almost as much as new XTR rear D. So - if you have any mechanical aptitude at all, do it yourself.
Posted : 30/03/2019 5:41 pm
Mine was just gummed up. Take off the little plastic cover, clean it out a bit and stick a bit of thin oil or lube in there.
Posted : 30/03/2019 5:42 pm
Thanks, will give it a clean up and lube, hopefully will fix it.
Posted : 30/03/2019 6:42 pm
had this once, I don't know what to call the part but a screw that acts as a stopper had fallen out. the cage would move very freely and no tension.
Posted : 30/03/2019 7:05 pm
