Realistically, how ...
Realistically, how much difference will 5mm of tyre width make?
 PJay
[#13535691]
I have a gravel bike and I find the front end a bit jarring on the ridiculously broken up & potholed roads I ride it on. It has a carbon fork, but with its wide, triangular blades it's clearly built for stiffness rather than compliance.
Tyres are 700x40 Maxxis Receptors (120tpi & nice & supple) running at 30psi. 40mm is the max for the frame, but the fork will take a 45mm.
I am a bit of a serial tyre swapper but tyres seem suddenly to be very expensive (I like the look of the new Continental Terra Competitions but they're around £120 a pair!).
The Receptors don't come any larger but there are plenty that do (Gravelking SS look interesting) but would the extra 5mm gain me anything much or should I just wait until they're worn out and have to be replaced?
Posted : 26/05/2026 11:12 am
Topic Tags
Yes they would make a difference. Whether it's enough to justify binning your current tyres YMMV.
Posted : 26/05/2026 11:16 am
My hands were a bit sore when I first started riding gravel.  I found that some gel inserts under the bar tape, gloves/mitts with a bit of padding and riding in the drops all helped.
A lot of mitts have good padding but gloves hardly seem to.  But I found a cheap pair of Boardman gloves in Halfords and they are excellent.
Posted : 26/05/2026 11:34 am
nickingsley reacted
I'm not in your position but surely one of those suspension stems would make the biggest difference?
Posted : 26/05/2026 11:39 am
convert reacted
A lot. I use 2.6" tyres on my MTB and find them so much better than 2.4"
Coming back to gravel, I bought my gravel bike specifically because it had 5mm greater clearance than the year before model. Whether it was worth the extra £500 and enduring shit gears is up for debate 🙂
Posted : 26/05/2026 11:45 am
Posted by: PJay
I wore out my 40mm tyres and replaced them with 45mm. The difference is noticeable but not so much I'd bin some good tyres for it.
How are you measuring the tyre pressure? I've found track pump pressure gagues to be less reliable at lower pressures so there's a chance you could be putting more than 30psi in there. I'd probably experiment with dropping a couple of toots out the valve to see if that helps.
Posted : 26/05/2026 11:50 am
The cross section volume of a tyre has fairly close to a square relationship of the width - volume approximates to Pi * Width^2 / 4 - so a 45mm tyre has approx 25% more volume than a 40mm (which allows a lower pressure to be run for more comfort)
Posted : 26/05/2026 12:02 pm
Posted by: PJay
Yes, I'd say so. I recently went from 40 WTB Nano's to 45 Maxxis Ravagers. Difference was very noticeable, although think the carcass of the Ravagers feels a bit thicker and better damped as well.
Posted : 26/05/2026 12:07 pm
It’s not just 5mm width, it’s a considerable increase in height and (therefore) volume.
I’ve usually got 45s on my gravel bike, but have just chucked a faster rolling 40 on for the summer months. The difference between the sizes is more than you might think
Posted : 26/05/2026 12:20 pm
b33k34 reacted
The problem here is that you're looking at a nominal width.
You need to measure the tyre on your (or an equivalent) rim width. A tyre measuring 44mm might have a 10% smaller volume than a 46mm tyre
Tyre construction will also play a part in the amount of compliance.
Posted : 26/05/2026 12:32 pm
 aggs
You could go up 5mm on the front and keep the rear the same and then when rear is worn you can swap it over to the fresher tyre.
I am just about to do this myself. I have the tyre just not fitted it yet , I may wait for the event I have entered ,and then fit it beforehand as the length of ride will be significantly longer than my regular rides.
So maybe some marginal gains on comfort for me.
I tend to ride the downhills a bit faster on events.
Posted : 26/05/2026 2:18 pm
Yes it makes a difference.
I found that gel and thick bar tape is as important.
I also think I can feel some firmer sidewalled tyres.
Posted : 26/05/2026 3:00 pm
nickingsley reacted
You also mention forks: I've had a pair of carbon forks that were borderline comfortable. My current steel Genesis forks are anything but...
Posted : 26/05/2026 3:05 pm
I bought the 45mm version to put on the rear, but you could get the 40mm version for the same price from Winstanley, mine took ~10 days to deliver.
https://winstanleysbikes.co.uk/hutchinson-caracal-race-700c-tubeless-tyre
The 45mm is super comfy at ~42PSI with latex tube and the 40mm has even lower rolling resistance.
Posted : 26/05/2026 7:57 pm
I discovered that, on my kona smoke 29er, it was difficult to find a sweet spot on the Conti travel contact 700x47 tyres, between rock hard and clanging the rims on potholes.
moving up to 2.0 made a colossal improvement.
but if you’re maxed out with 45c at the front, would a switch to 27.5 at the rear widen (😩) your options?
Posted : 26/05/2026 8:27 pm
 P20
It should make a lot of difference. I went from 44 to 47mm and you could feel it
Posted : 26/05/2026 9:56 pm
 PJay
Perhaps I need to have another look at tyres.
The Panaracer SS look decent, I don't need anything too chunky. Any experiences?
Posted : 26/05/2026 10:02 pm
The other thing to consider is are they actually any bigger?
Different tyre manufacturers size differently, and sometimes the same manufacturer across a range (for instance my 2.35" Maxxis Ikons, while clearly larger than my 2.1" Ikons, seem a _lot_ smaller than my 2.4" Minions) I've no experience of those.mentioned in the OP but I've had problems with a 2.3" Panaracer actually being larger than a 2.35" Maxxis!
So is a 45mm Conti actually any bigger than a 40mm Maxxis? Don't just go by the printed numbers, for small differences measure them
Posted : 27/05/2026 12:36 am
Haha, in true STW style not answering your question, but if you are able to slide your saddle back on its rails 5 or 10mm you should find that your hands/arms/shoulders take less of a beating by being slightly unweighted. It's a bit counter intuitive, but has worked for me. Only useful if it doesn't end up knackering your knees by being too far back etc.
Posted : 27/05/2026 9:18 am
No mention that I can see about if you are running tubeless or not and what pressure you are running. Are you running same/similar front and rear.
Even on road you can run your front tyre a lot soft than you might expect, especially if run tubeless. A lot of folk, especially if they have a road background run old skool road tyre pressures backed off a bit (because they know the tyres are bigger) when in reality they can be backed off a lot.
I'd be experimenting with tyre pressures (and going tubeless if not already) before resorting to new tyres.
Posted : 27/05/2026 10:53 am
Do it and you’ve got a spare rear tyre.
Double win.
Posted : 27/05/2026 7:21 pm
 PJay
Sorry I forgot to mention that they are being run tubeless. 30pso both ends but I'll experiment.
Posted : 27/05/2026 8:00 pm
 PJay
Well I went for the Caracal Race tyres (40/45) and I can't believe how much bigger the 45mm one is, in fact I actually think the bike looks a tad odd with the mismatched tyres & I'm wondering whether I could squeak a 45mm one both ends. I think it might be a bit tight though (the front mech adapter reduces clearance a tad and for some reason Ragley decided to run the rear brake hose of the Trig along the inside of the chainstay & I don't want the tyre buzzing the hose). It's a steel frame too so will have some flex & there's no point wearing the chain stays for the sake of aesthetics.
I gather that a larger front tyre isn't unusual and it certainly does make a difference to comfort. I'll experiment with tyre pressure too although I'm currently below 30psi.
Posted : 05/08/2026 8:12 am
Caracal race is top of my list for some new road* tyres for the warbird. Also think I might be on 45f/40r if I want to be able to get mudguards on. Very interested in the difference in sizes- what width rims are you using?
*for a very wide definition of road
Posted : 05/08/2026 9:43 am
I found the same. Put a 45 on the front of my gravel bike. 40 on the rear.  But the 45 did feel a heck of a lot better than I thought it would. A bit squidgy on the road ,but so smooth! On gravel another little bit  but more comfortable as well.
I am glad I did not go 50mm (at the moment!)
A 45 on the back is a nice to have but will wear out my 40 s first. I do have the clearance.
Maybe eventually I move 45 to back and 50 on front but they are hefty tyres!
Not worried about the looks.  I doubt most people would notice anyway.
Posted : 05/08/2026 10:33 am
I might have already posted this.....
As another trig owner Id settled for 40mm as the widest in the rear on a 700c you could get in with any sort of clearance. Though obviously not all brands are the same - some have small penis syndrome and their claimed 45mm is really 42 or whatever.
However.....have some real fun and get some 650b wheels alongside your 700c pair. Then you can have a real range. I now have 2.1" on the 650b and 40mm on the 700c and am set for rides that are mostly roads with some smoother gravel or routes that are edging into mtb territory.
Posted : 05/08/2026 10:43 am
 PJay
I'm not sure what the rim width is. They're DT Swiss G1800 wheels but the older 3 pawl design (the rim width may have changed when they upgraded the model to Ratchet LN and I've just had an email from Freewheel advising that the 'New' G1800s have wider rims).
Much as I'd like a 45mm rear tyre I think that sticking with 700x40 (Ragley's own Max. spec.) is the sensible thing to do.
The Caracal Race are really nice tyres (but I could be tempted with the new Continental Terra Competitions).
https://1drv.ms/i/c/6adcda47576a022a/IQSo95FQApCSQoFMM-x9ufTNAfr01q67ouj0nVajSWRcUfk?width=4000&height=3000
Posted : 05/08/2026 11:34 am
I use a 5mm wider version of the same tyre on the front... for the same fork/frame clearance reasons... works a charm... much more comfortable... no downsides of any kind.
Posted : 05/08/2026 11:38 am
Rear 45mm Caracal Race measures ~47mm on 21mm internal rim width wheels on my Bolt after five months riding at ~42psi with latex tube.
Posted : 05/08/2026 12:06 pm
Ragley Trig owner here - I've got a 45mm Panaracer Gravelking X1 in the rear with no issues (and a 50mm up front). DT Swiss G1800 rims.
My clip-on rear full length mudguard might be a squeeze against the seat tube however, but haven't had a need to put it on for 3 months!
Posted : 05/08/2026 12:47 pm
Posted by: andrewh
http://www.reifenbreiten-datenbank.de/ is your friend here. Or it was, the site seems down right now. hopefully not permanent
Posted : 05/08/2026 12:49 pm
I’d say that is a bit odd with 40mm tyres.
I’ve got 35mm road tyres on my gravel bike and it glides over everything within reason
Id be looking more at bike setup as noted by one person above. Ie how much weight is through your hands, bar angle, hood position, stack and reach
Posted : 05/08/2026 1:31 pm
I went from 40mm F&R (which I was pretty happy with) to ~52mm F and 47mm Rear and it's certainly an improvement in comfort and rolling (IME/IMO).
I would definitely go as wide as possible on the front that seems to have the biggest impact on arm, neck and upper body comfort over several hours of off-road riding, I would also play with pressures, I bet you can go lower than you think...
Posted : 05/08/2026 2:03 pm
Nobodyofthegoat that’s exactly the number I was looking for, thanks!
I run 50mm wide tyres front and rear on my Revolt. Tyres are Shwalbe G one Rx front R on rear. Tyre pressures are 20psi. I don’t find the bike that jarring. It’s obviously not as smooth as my Xc full  suspension bike on 2.4inch Maxxis Rekons. I suppose it all depends on what surfaces you ride on. I ride on a lot of chunky gravel, say 40%, some champagne gravel 40%, some singletrack and some tarmac say 10-15%. I reckon 30psi would be very jarring for me on the chunky stuff.
Posted : 05/08/2026 2:23 pm
I'd suggest you need your weight to that - at my portly mass 20psi would be....... interesting!
Posted : 05/08/2026 2:30 pm
I’m around 65kg, once you add bike and clothing probably total system weight is around 77kg.
Posted : 05/08/2026 3:28 pm
I'm surprised the Caracal's are oversized on a 21mm internal rim, my 45's measure 48.2mm but they're on a 32mm internal rim - generally gravel tyres should be true to size on a 24-25mm internal. They are a great tyre though, have over 2500 miles on mine (probably 60% road), they surprised me how good they are off-road (as long as it's dry and not above 15% if it's a loose surface climb).
I generally don't run the front off-road though as it can be a little sketchy on anything loose if pushed a bit when cornering. The shoulder knobs are prone to tearing to, had to plug them a couple of times when a knob has torn clean off deeply enough to let air escape (that was from rocky technical descents though)
Posted : 06/08/2026 7:42 am
Went from 40mm to 47mm. Night and day difference but as others have said, its more about the overall volume than kust the width.
Changing tyre pressure during a ride might help you even more. I found my ideal pressure for gravel/woods etc felt pretty sluggish on tarmac.
Posted : 09/08/2026 11:32 am
