Who is running an r7000 GS rd without any mods or extension links over 34t?
What size cassette?
Works fine with sram 11/36, just some B screw adjustment
Ran it for a bit on a cannondale slate with 50/34 chainrings. Only issue was a slack chain in small/small
it's all down to b screw length
I'm running the ultegra r8000 equivalent with an 11-34 on the back, and absoluteblack 46/30 super compact front, and no probs. Could probably lose a couple of links on the chain, but just don't go small to small
More the other way, as in bigger cassette size
I think you can go 11-36 if you can find one...think that's XT tho....
Cassette wise 11-40 is my choice (slx)
Wondered if anyone had managed it that's all
Can't see it happening.
you can get a grx810 for fifty quid though.
@jonnboi but I've already got the r7000 lol
Don't need to do it just inquisitive about what people have achieved
Grx810 is 34t also
I have it working with a 42T in 1x
you weren't ever thinking you were going to get a 105 GS mech to run a 40T cassette AND a double were you?
No
I'm new to gravel and rd but enjoy the road Speed
Currently have 8 speed 11-32 but coming from 12 speed 10-51 find it gappy obviously
I've got in the spares a couple of 105 GS rear mechs, an 11-42 cassette, a 40t apex crank.
Currently have a 50/34 105 crank on the bike so would just need shifters.
If I buy the 105 shifters then I can trial both options and see what I like most with minimal fuss
Double setup with 50/34 and 11-32 cassette
Single setup with 40t front ring and 11-40/42 rear
Just seeing what's real life workable whilst deliberating
I have an ultegra 50/34 double chair set and changed to an r8000 GS rear mech, specifically to enable a larger cassette. I think I have an 11-40, but I set it up a few years ago and can't remember, exactly.
Let me check, when I get a mo...
Yes I have run that cassette for two years. It was perfect for the Fred Whitton
I run on my tcr 34/50 front and slx 11-40 cassette on the rear. Wind out b screw works fine.
ran it like this for two years.
My wife ran 11-40 with 46/34 with R8000. It worked ok, but changing to GRX, it does shift better
I have an ultegra 50/34 double chain set and changed to an r8000 GS rear mech, specifically to enable a larger cassette. I think I have an 11-40, but I set it up a few years ago and can’t remember, exactly.
Let me check, when I get a mo…
...so, I checked, and the cassette is 11-40 (CS-M8000)
R8000 & R7000 are both 39t capacity, BTW
50/34 and 40T should work fine. My Amazon has been set up like that for years with the Ultegra mech. I doubt the 105 is any different.
Right off to buy the shifters
