Re-proofing eVent f...
[Closed] Re-proofing eVent fabric
 Alex
Right I've read many threads about this, and I'm still confused. It's a Endura eVent jacket. Not beading at all whenever it rains (so most days then at the moment). I've tried washing it without detergent, ironing it, throwing an eye of newt in the machine, etc without much success.
What's the right way/product to sort this. Ta.
Posted : 23/07/2009 12:07 pm
Wash with Nixwax techwash(i think graingers does the same job but not sure)
then water proof with a wash in waterproofer again by nikwax. Most outdoor shops will have a little branded nikwax display somewhere in store. Be warned its not cheap but will make your jacket work.
I can't imagine ironing it has done it much good though...
Posted : 23/07/2009 12:14 pm
Ironing eVent is recommended, as it rejuvenates the DWR at warm temperatures.
Posted : 23/07/2009 12:25 pm
grangers works
iron or tumble dry after or its no good
Posted : 23/07/2009 12:26 pm
I was told by an experienced climber never to use a wash-in proofer on eVent or paclite as it 'proofs' the inside of the garment too. This will prevent it from breathing and essentially turn it into a kagoule.
Nikwax & Graingers both do spray on ones.
Posted : 23/07/2009 12:37 pm
http://www.eventfabrics.com/care_and_maintenance.php
To summarise:
Wash regularly at 40 degrees with a liquid detergent - but ensure all detergent is rinsed out.
Don't iron
Use proofer, no comments to avoid wash in.
Posted : 23/07/2009 12:41 pm
Interesting Nobby, I thought it would do the same, and questioned some Grangers reps who visited out store. Wish I could remember what they said... ๐Ÿ˜ณ
Ironing doesn't seem to damage the jacket, but doesn't seem to do much for the DWR. Tumble drying, on the other hand, works wonders for the DWR, and doesn't [i]seem[/i] to damage them, half hour on medium heat seems OK.
Posted : 23/07/2009 12:43 pm
Tumble dry mine, seems to do the job
Posted : 23/07/2009 12:51 pm
 Alex
Ta all. I'm going with the simple option then. I just need to find our tumble dryer that's buried behind some house renovations. Looks like I'll need to find it before tonight's ride ๐Ÿ™
Posted : 23/07/2009 12:52 pm
thepurist - Member
To summarise:
Don't iron
Maybe not, but it shows both Graingers and Nikwax spray-ons and does state:
"Your eVent garment contains a durable water repellant finish (DWR) [b]on the exterior of the fabric[/b] that serves as a first barrier to penetration of the fabric by external water. "
Surely if you apply a DWR to the inside of the garment you are waterproofing it must stop sweat passing through?
Posted : 23/07/2009 1:01 pm
Well, the sweat has to pass through a DWR at some point doesn't it? So maybe having two layers of the DWR doesn't really make a difference?
That said, after the first time I reproofed my jacket, it felt sweatier, which maybe proves the point. Will definitely try the spray on stuff next time.
Posted : 23/07/2009 1:36 pm
 SiB
JUst a quick hijack - grainger says to tumble dry but garment states do not tumble dry..........would ironing be similar to tumble drying it? safe to do so?
Posted : 23/07/2009 1:45 pm
Our tumble dryer has a 'cool' setting which I use without any problems.
Posted : 23/07/2009 2:42 pm
