Racing Ralphs in th...
[Closed] Racing Ralphs in the wet?
[#5802713]
Specifically Thetford/Brandon and specifically rear only for racing. I've only ever ridden them in the dry.....?
Posted : 27/12/2013 9:47 pm
Well they won't grip as well as a mud tyre but in less it's very muddy you'll be alright.
Posted : 27/12/2013 9:51 pm
I was out on mine yesterday in gloop and roots, they were ok at slow speeds but a little faster and they felt a bit twitchy.
I've ridden on worse tyres.
Caz xx
Posted : 27/12/2013 9:52 pm
Have them on my new cross bike, and they were good while it was tipping it down the other day. Mtb type cornering may be different.
Posted : 27/12/2013 9:54 pm
I found them more predictable than Nobby Nics when things get slippery
Posted : 27/12/2013 9:55 pm
Fine on the rear traction wise,not so good braking wise..If they're 50% worn they can be riot on wet muddy stuff,loads of drifts....
Posted : 27/12/2013 9:58 pm
That's a worry box fish , there's a Nic on the front.....
Ok out back but on the front......washout
Posted : 27/12/2013 10:10 pm
ridden my 2.1 's in clay and peaty soil and was quite surprised how well they worked. Yes, a bit of oppo at times, but still kept the speed up when needed.
Posted : 27/12/2013 10:12 pm
Yeah. I thought the nobblier Nobby would perform better on the front when things got sticky.
I just didn't get on with it at all. Even tried reversing it to see if that made any difference.
Posted : 27/12/2013 10:18 pm
I run a tubs version of them front and back on one of my cross bikes and IMO they are very good in wet muddy conditions but guess that could be down to me running at a low of 24/26psi and in turn getting plenty of grip, I also run top end cross tires on another bike and so far IMO the RR's do as good of a job and at a lot less cost...
Posted : 27/12/2013 10:19 pm
 gee
If they're tubeless, just drop the pressure to 25psi and you'll be fine.
I used Ralphs for all the extremely wet D2Ds - fine.
GB
Posted : 27/12/2013 10:28 pm
They are predicatble in their lack of traction ill give them that... Fairly controllable but if its that real slipy slimy stuff (Like the route from chingford to epping today! God that was slidy... But fun!) rather than the fudge then forget about traction!
Rocket Ron if your not willing to compromise all the way to a beaver? I use one up front all year find it really good in the mud due to the block spacing but still really fast.
Posted : 27/12/2013 10:29 pm
JESUS CHRIST OP?!??!
IN THE WET?
FOR THE LOVE OF GOD, MAN, NO!
Posted : 27/12/2013 10:36 pm
Better on 29er
Posted : 27/12/2013 10:38 pm
I run them year round. They have a limit, but when they let go it's predictable. So I stick with them.
Posted : 27/12/2013 11:02 pm
Good luck 😯
Posted : 28/12/2013 1:11 am
Wet xc racing = WTB Raijin
Posted : 28/12/2013 2:59 am
As others have said slippy but very predictable in the wet. Mines nearly bald at the back. With a nic on the front. And they cope well at thetford and brandon. Well for me anyway.
Posted : 28/12/2013 7:43 am
RaRa on the rear of my bikes for years, better in the larger sizes with low pressure
They need to make thunder Burt's wider as well
Posted : 28/12/2013 8:30 am
Thunder Burt in the wet could be 'interesting'...
Posted : 28/12/2013 8:51 am
 gee
I ran Burts at D2D this year - they became interesting when there was a light dew.
GB
Posted : 28/12/2013 9:29 am
IME they're less shit that you'd think they'd be. That's not to say they're any good, and you'll waste a lot of energy trying to make a sliding tyre grip, but they're not as 'dump you on your arse as soon as look at you' crap as you'd expect.
Posted : 28/12/2013 9:56 am
Get a winter set of tyres
Posted : 28/12/2013 10:00 am
I've run them all year round. Grassy wet clag was an issue, but otherwise pretty good. There's always varied terrain on an off road ride, and they make up for it with their speed everywhere it's not uphill grassy clag.
Slide a bit, but hook up....in the end.
Posted : 28/12/2013 10:32 am
Never mind wider thunder burts a cx version would be lovely.
Posted : 28/12/2013 10:36 am
Pawsy_Bear - Member
I've four Mud X in the man cave, don't fancy racing on those.
But I have 2 Crests, 2 Ralph's and a Nic in front of me and I need a Jan - Mar set of tyre s mounted tubeless, and I'd like only to go through the process once.
Or is there a better fast rolling mixed conditions rear tyre to look for, and leave the Ralph's for drier conditions?
Posted : 28/12/2013 10:54 am
I'm of the opinion that if you are worrying about tyre choice i.e. don't have a bank of experience to draw on, then it really doesn't matter what tyre you race on. The differences are measured in seconds and you'll be far better off outside doing hill repeats than spending time thinking about it.
I'm not trying to be patronising, just feel I should make the point.
Posted : 28/12/2013 10:59 am
I'm running a Racing Ralph rear and a Mountain King Racesport (2.2 Black Chilli) on the front of my hardtail. I know a lot of people don't get on with MKs, but I have had them on a number of bikes, so I'm used to them, which gives me confidence.
It isn't very rocky in kent, so took a chance with the Racesport version.
So far, so good.
Posted : 28/12/2013 11:03 am
Rollindoughnut I hear you, a valid and correct point thanks.
Posted : 28/12/2013 11:10 am
I prefer Rons for winter use, a little more tread in the centre. You won't die either way though.
Posted : 28/12/2013 11:23 am
I always use Ron front Ralph rear at Thetford all year round, it's not sticky mud so never had a problem. Can't be bothered changing tyres every 5 mins so just get on with it
Posted : 28/12/2013 11:36 am
