If you're only using a single chainring then the object must be to get a sweet arrival/departure (my words) of the chain onto the ring at both extremes of the cassette, right? Can anyone tell me if they have had similar experiences to mine, where I've had to move the 2 x 1mm spacers of my Deus cranks to the non-drive side AND use 2 x 2.5mm spacers to the non-drive side on a 68mm shell to get mine looking half right? If I set up the BB with the spacers as they should be, and the 1mm spacers one each side, the chain drags at a hideous angle in low gear. Given the nature of the ring with it's stand off threaded nature, I expected the opposite? Anyone tried and found the same? On a 73mm shell it's not so bad, but the 2 x 1mm spacers give the best result if they are non drive side...
mart - Member
No.
It looks and sounds rough if I don't set it up as I've descibed.
Which side of the spider is the chainring on?
On the inside.
clubber - MemberWhich side of the spider is the chainring on?
Exactly what I was about to say.
On my Zee cranks, the chain-ring should be mounted inside. For some reason, When throwing a new ring on, I went in to muppet mode and put it on the outside, that caused all sorts of weird noise issues etc. Took me ages to figure out why aswell.
