PSA: XT M8000 crank...
[Closed] PSA: XT M8000 cranks - 175mm - 32t - £62.11 at Merlin
 nre
Just ordered mine!
https://www.ribblecycles.co.uk/shimano-xt-m8000-11spd-single-cset-inc-bb/#pid=33372
Posted : 15/01/2019 3:21 pm
Same price at Ribble, too!
Posted : 15/01/2019 3:37 pm
Thanks for the PSA, have ordered one.
Posted : 15/01/2019 3:51 pm
 nre
Doh - title should have said Ribble!
Posted : 15/01/2019 3:55 pm
Needed a set for the new Stooge- thanks.
Don't these need a new funny BB, or will my old SLX BB work?
Posted : 15/01/2019 3:59 pm
 feed
Just ordered, thanks for the PSA
Posted : 15/01/2019 4:17 pm
Cheers OP.
It will.
You may get a new one in the box anyway though, even if listing says not.
Posted : 15/01/2019 4:22 pm
Could these be used with a PF92 Bottom bracket for a trek remedy .?Also rear wheel is Boost spacing if that makes any difference. Thanks in advance.
Posted : 15/01/2019 4:33 pm
Even cheaper for me then!
Second hand prices of cranks stay pretty high.
Heel rubbed SLX/XT previous gen ones are over £50, so this is a no brainer.
Posted : 15/01/2019 4:35 pm
There are quite a few cheap cranks there including Deore and SLX. Anyone seen some 170mm boost M8000?
Posted : 15/01/2019 4:36 pm
Cheers for that shame they have no SLX rear mechs or shifter
Posted : 15/01/2019 4:44 pm
Damn will they be ok with a boost rear hub says 142!!!
Posted : 15/01/2019 4:47 pm
I run a none boost crank with a boost hub- general consensus is that the chainline is fine, it's more the chainring clearance. If you can squeeze the 32t in, you'll be fine.
Posted : 15/01/2019 4:54 pm
PSA: race face turbine for £100 on wiggle /crc, non boost and only comes with a 28T chain ring..
otherwise i'd have had one
Posted : 15/01/2019 5:11 pm
yay got the last bottom bracket for £7 and a reduced sram chain just need a deal on a 11-46 cassette now
Posted : 15/01/2019 5:22 pm
There were some SLX cassettes very cheap on Ribble last night (11-46), but I'm guessing they've gone now.
Posted : 15/01/2019 5:24 pm
Cheers, ordered.
Posted : 15/01/2019 5:46 pm
@postierich - ya bastard 🙂 I had it in my basket but was in a meeting so when I went to checkout I was told they'd run out of BBs 🙁
Posted : 15/01/2019 6:29 pm
matching BB for not a lot
https://www.chainreactioncycles.com/shimano-xt-mt800-bottom-bracket/rp-prod135826?mx=a
Posted : 15/01/2019 6:37 pm
Thanks for the PSA.
XT chainset ordered along with an SLX 11-42 cassette for £34.14. Bargainlicious.
Posted : 15/01/2019 6:52 pm
I need a 11/46 🙁
Posted : 15/01/2019 7:10 pm
Thanks op!
Aaaaand, were off! first component bought for the HT build...
Posted : 15/01/2019 7:48 pm
Those of you looking at the turbine the non boost is fine for boost. The difference is in the ring so sell the ring and buy a boost one.
Posted : 15/01/2019 8:04 pm
Great spot. Given the chainring alone seems to sell for over £30 that price for the whole chainset was hard to ignore so I’ve bought one.
Shifters going cheap too...
Posted : 15/01/2019 9:24 pm
Yep, crank without ring on the same site is £61.93, so a chainring for 18p.
Posted : 15/01/2019 9:33 pm
Other than length are all the m8000 cranks the same? As in boost and non boost? Its the offset made by the ring or are they actually different q factor?
Some bargains on the 2x ones to be had if all you need to do is swap the chainring out for a single boost one?
Posted : 15/01/2019 10:37 pm
Great psa thanks.some good prices. Set of 2x10 deore cranks ordered for my son. Trying hard not to get xt cranks and saint pedals.......
Posted : 15/01/2019 11:48 pm
Thanks-great PSA!
Posted : 16/01/2019 12:14 am
Cheers OP. Order has just landed.
Posted : 18/01/2019 1:21 pm
Code jan50 saves another 50% on some lines (not Shimano though). DT swiss m1900 wheelset for around £100 any good to anyone.
Posted : 18/01/2019 7:47 pm
Arrived the other day with chain and BB see the cranks have gone unto £120+
Posted : 18/01/2019 8:38 pm
Darn, yeah back up at £120.
Grabbed a 105 5800 chainset for £49 from Ribble though, spot on!
Posted : 18/01/2019 9:25 pm
Mine arrived and fitted this evening. Man logic dictated that this was a better use of money than buying a powerspline BB for the existing SRAM cranks 😀
Posted : 18/01/2019 10:37 pm
