PSA - NX groupset n...
PSA - NX groupset now £145 at CRC
16 Users
It might not be the best or the lightest, but £145 for the whole groupset is irresistible.
This includes an extra £10 off for CLEAR2022.
https://www.chainreactioncycles.com/sram-nx-eagle-12-speed-mountain-bike-groupset/rp-prod172474
Posted : 21/12/2022 10:45 am
Great PSA
Posted : 21/12/2022 11:22 am
Great but not boost if that matters
Posted : 21/12/2022 11:42 am
Good price, wouldn’t have got that a couple of years ago. Non boost chainring looks like the only possible downer
a new chainring will sort that 🙂
Posted : 21/12/2022 11:43 am
Boost chainrings can be had for £15ish iirc
Has NX got any better?
my experience with serially failing NX mechs really put me off
Posted : 21/12/2022 11:46 am
They had a good deal on this a while back, but not sure it was that good.
Anyone know if it's possible to run these on a press-fit BB?
I'm debating this for my Stumpjumper FSR to bring it into the modern age. It's currently on 3x9 triple and has got a BB-92A press-fit BB, I think.
Current crankset is HTII XT.
Posted : 21/12/2022 11:47 am
BB-92A press-fit BB
I think it’s one of these
https://www.chainreactioncycles.com/sram-dub-pressfit-mtb-bottom-bracket/rp-prod170696
Posted : 21/12/2022 11:51 am
Been running it on my hardtail for a couple of years and it's been fine, at this price probably worth it for spares!
@stumpy01 yes, you just buy a DUB bottom bracket that suits your frame. I think you'd need this one but BB standards confuse the hell out of me.
Posted : 21/12/2022 11:59 am
Great! Cheers simon_g & rubber_buccaneer
Posted : 21/12/2022 12:35 pm
Thanks OP, this will go on the El Guapo
Posted : 21/12/2022 2:36 pm
Could do with a new groupset on my Mk1 Solaris, which is running a Shimano set up
Can anyone please confirm
- will the cassette fit a normal freehub. My happens to be a Hope pro 2 evo one but it's running a normal Shimano (11-40 I think) cassette
- I'm running a screw in Hope bottom bracket on the bike, can I buy an adapter to convert mine to be dub friendly or will involve a whole new bottom bracket? (and potentially a tool to fit it)
Posted : 22/12/2022 9:09 am
Normal HG freehub, yes.
Hope DUB converter requires a 30mm BB (not a 24mm one), what are you running at the moment?
Posted : 22/12/2022 9:18 am
NX cassettes fit old style freehubs, they only go down to 11. If it goes to 10 like GX it needs the XD driver.
Admittedly I never used it that much before selling the bike but I had NX 11sp on my Hardtail and it was faultless. I set it up once and never touched it again for 3 years.
I’ve got a temporary NX Eagle shifter in place of my GX and can’t say I notice any difference in use (I will put the GX one back on when I have it though just because).
SX is the current snappy one I think.
Posted : 22/12/2022 10:09 am
Quick follow up.
Mine has arrived already - so less than 24 hrs (on standard delivery). And its not even OEM. Proper boxed stuff.
Posted : 22/12/2022 10:16 am
@kelvin - I think it's 24mm, it's a Hope screw in BB to fit a Shimano Zee crankset from 2014, I think it's 73mm wide
I think that means I need a new threaded bottom bracket if I want to go with this groupset. At least the Cassette will fit ok I suppose
Posted : 22/12/2022 2:47 pm
That sounds right.
Posted : 22/12/2022 5:31 pm
Is it correct that the boost part of the chainset is just the chainring?
So a boost direct mount chainring will make it all fine with 52mm boost chainline?
Ian
Posted : 22/12/2022 5:49 pm
Yes it is for SRAM.
I think 3mm offset is boost and 6mm non boost.
Posted : 22/12/2022 5:55 pm
Ace. Thank you
Ian
Posted : 22/12/2022 6:02 pm
The rear mech fragility can be totally solved by retrofitting a X01 hanger bolt assembly thing, not sure what the proper name is. £25 or so.
Excellent price for the groupset.
Posted : 22/12/2022 6:24 pm
They now have boost. Same price no voucher code. Bargain!
Posted : 22/12/2022 7:08 pm
NX is still going strong on my 2000 mile old Whyte 901. I’d buy this if they had 165mm cranks in stock.
Posted : 22/12/2022 9:06 pm
