PSA New Edge 705 fi...
[Closed] PSA New Edge 705 firmware update (V 3.1)
Hopefully goes some way towards solving the elevation calibration problem.
Posted : 05/12/2009 9:42 am
Nice one, thanks Dibbs.
Posted : 05/12/2009 11:22 am
Thanks Dibbs
Posted : 05/12/2009 1:32 pm
I can't get 3.1 onto my new Edge 705 (shipped with 3.0). I'm using the WebUpdater, but nowt is happening. Anyone else have problems?
Posted : 11/12/2009 3:33 pm
Did mine 2 days ago with no problems ๐Ÿ™‚ Maybe server is busy/down - try again in a few hours/tomorrow!
Posted : 11/12/2009 4:57 pm
does it see the device Druidh?
if not then try re-installing the usb drivers
Posted : 11/12/2009 5:03 pm
Nah - It connects to the server OK, recognises it needs to do an upgrade, downloads it and then seems to apply it to the GPSr. I even get a "your 705 had been updated" message. When I switch it on and look at Settings..System..About, it still says V3.00
Posted : 11/12/2009 5:06 pm
drop garmin an email, they normally reply within an hour although it's friday afternoon
Posted : 11/12/2009 5:07 pm
How about this:
https://forums.garmin.com/showthread.php?t=4094
"Garmin are aware and are emailing out a zip file to enable a manual update - but yes - jimwhimps's solution works - thanks Jim "
Posted : 11/12/2009 5:28 pm
I worked it out.
I needed to plug it into power from the wall.
Posted : 11/12/2009 5:31 pm
Meh - that hasn't worked either. I can see the updated GCD file on the "E:\" drive (i.e. 705 internal memory), but the unit doesn't seem to want to boot from it for some reason.
Posted : 11/12/2009 5:52 pm
oh ok - Garmin tech support it is then I think ๐Ÿ˜‰
Posted : 11/12/2009 5:59 pm
Hello Dibbs! I didnt get a dip when it started raining. Well, not that I can see!
Posted : 11/12/2009 6:27 pm
Charlie you couldn't miss it if you had the problem, it looks like this:-
[img] http://images.fotopic.net/?iid=117f1c&outx=600&quality=70 [/img]
The ride should have ended at 200ft, not over 1000ft in the air above my house.
Posted : 11/12/2009 7:08 pm
