PSA - Bargain Edge ...
[Closed] PSA - Bargain Edge 800's
Any good for off road use?
Posted : 19/12/2011 9:37 pm
Sent you an email kryton57.
Posted : 19/12/2011 10:31 pm
out of interest, does anyone know if non-garmin heart rate straps are picked up, eg polar?
cheers 😕
Posted : 19/12/2011 10:46 pm
You need an ant+ protocol HR strap - so Polar won't work.
Posted : 19/12/2011 10:50 pm
Hmmmm! Late home & busy all evening has meant that I haven't ordered one yet.
One question to anyone who knows...
My mate has got an older Garmin; the 305 I think. It does the route thing of giving you a line to follow on the screen & I think a heading when you get to a waypoint; although it might just tell you if you are deviating from the programmed route.
I assume that the 500 does this, but I read a review (I think on Bike Radar) that said that it didn't have this functionality and was pretty much a glorified cycle computer aimed at racers. I then found another review that said you can load maps to it and follow it....
Don't really want to buy it if it is just a glorified hi-tech cycle computer....
Posted : 19/12/2011 11:26 pm
Thanks for heads up guys, ordered 800.
Got a memory map 2800 going cheap now if any ones interested!?
Mike
Posted : 20/12/2011 12:38 am
To the OP, my thanks!
Posted : 20/12/2011 12:45 am
Massive thanks OP ! - Gosh you have saved a lot of £££ to a fair few people tonight. Its surprising how many people can all of a sudden find a couple of hundred quid at the most expensive time of the year 😳
Got mine for £253.79, thanks to frogstomp for the voucher code : NUSDEC11
and i also got a extra 4% off going through Quidco.....
Posted : 20/12/2011 2:36 am
I almost pushed the button, then remembered mortgage, car service and MOT, guess i'll have to stick to getting lost
Posted : 20/12/2011 7:14 am
You can't load maps, but you can load routes, so you follow a line basically, and if you manually input them you can do turn by turn navigation..
Posted : 20/12/2011 7:38 am
 cp
You're all welcome 🙂
Sorry for causing more expenditure at this time 😉
I was going to PSA it after I ordered mine but by the time I got round to doing it that evening, they'd sold out...
Posted : 20/12/2011 10:06 am
warton - Member
....and if you manually input them you can do turn by turn navigation..
Really? How/explain please?
Posted : 20/12/2011 11:23 am
 Jase
Manually create the route (using Garmin Connect for example) and then download to the Garmin.
Posted : 20/12/2011 11:25 am
Another question - I've read a lot about .fit files. Is this the only file that the 500 will accept?
Can I upload a gpx route to the 500?
Or is there some software that will convert it?
Posted : 20/12/2011 11:27 am
But Jase, how does it differentiate from the "line drawing " of following a route? I assumed he meant thet it would "point" left/right?
Are you saying if you manually create the route you get a left/right symbol, whereas if you follow a predetermined route you/someone else has ridden before thats NOT created manually you just get a line to follow?
Posted : 20/12/2011 11:31 am
I must say I thought you could only follow a 'breadcrumb' trail on a 500, although Warton's post seems to suggest otherwise. How does it know that you're coming to a proper turn though? Surely it doesn't have the software for that?
Posted : 20/12/2011 11:47 am
 Jase
I've only used it a few times to follow a route I manually created on a website first(can't recall the site but it wasn't Garmin as they didn't offer the feature at the time).
It does only show you the line but does bleep when you need to turn.
It knows you are comming to a turn as the route was cretaed using a 'proper' map.
Posted : 20/12/2011 11:52 am
 cp
I would be very suprised if the 500 did give turn by turns - like njee20, I thought it was just a breadcrumb line with a little pointer as to where you were. Which is fine, if you're happy with that & take a seperate map out with you.
Posted : 20/12/2011 11:53 am
 Jase
It does, I've used it (see above).
 cp
Jase - does that only work for road based rides then, not off road, if you're using a website to create it? I guess the 500 is seeing significant changes in direction as a waypoint & alerting you when you get close.
Posted : 20/12/2011 11:54 am
 Jase
I assume that the website used to create the route inputs the waypoint and the 500 simply recognises this and performs the alert.
I guess if you create an off road route and create a waypoint it would recognise this but purely guessing.
It works well enough on the road as even though there is no map, when it alerts you to turn its usually quite obvious where the turn is. Off road this probably wouldn’t be as obvious if there were trails everywhere.
Posted : 20/12/2011 12:03 pm
It doesn't. you need to manually add a turn when creating the route on something like bike route toaster
[url= https://forums.garmin.com/showthread.php?p=86200 ]linky[/url]
Posted : 20/12/2011 12:05 pm
Briliant.
I've got fed up with my Mem Map 3500 going wrong all the time, so it may get replaced...
Posted : 20/12/2011 12:15 pm
 mos
Could i buy one of these & add 1;25000 for my local area at a later date?
Posted : 20/12/2011 12:36 pm
Too much hassle for me. I'm using mine (on a unknown route basis) for road and find that following the line is easily indicative of left or right. I have actually followed a long route before but have a unknown 100k in the device which I may ride next Tuesday (Turkey Fat reduction plan).
FWIW I wouldn't use it in the woods, only for longer rides where I don't need to know which piece of 5 pieces singletrack to follow every 200m, but just the general direction to follow. If I neeedded that I'd buy the 800.
Posted : 20/12/2011 12:55 pm
My edge 500 has just been deliverd. Thanks very much for the psa cp.
and thanks for the deal on the additional sensor Kryton57. Now sorted for both my road bike and commuter.
Posted : 20/12/2011 2:11 pm
Another question for those who have the edge 800,
those openstreetmap links posted by cp above have downloads of jpg map files of all sorts of countries.
If I download a jpg and bung it onto my miniSD card, can i put this into the edge800 and will it read it? does it know how to locate the all the jpg maps relative to GPS?
i guess it wouldn't do satnav type routes, just show you where you are right?
so does that mean that the 1:50bundle OS has more map data in?
thanks! 😛
Posted : 20/12/2011 2:17 pm
 cp
no, it's not the jpg you need - that just gives an overview of what's included. You need a .img file which are linked to... and it needs to be a 'routeable' one.
Posted : 20/12/2011 2:39 pm
 sok
Dear OP
I love you
Posted : 20/12/2011 3:57 pm
Cheers OP, finally found something the missus can buy me for xmas 🙂
Being delivered Thurs and opened Sunday 8)
Posted : 20/12/2011 5:59 pm
Darn... out of stock now!
Posted : 20/12/2011 9:17 pm
Anyone had their order confirmed yet
They've taken my money, but still shown as processing
Posted : 20/12/2011 9:34 pm
confirmed, delivered and fitted to the bike tonight 😀
Posted : 20/12/2011 9:35 pm
I expect mine will be sent tomorrow as I've selected delivery for thursday, missed wednesday slot by 8 mins 🙁
Posted : 20/12/2011 9:39 pm
Just helped myself to a 500...happy crimbo to ME...well thankme verymuch.
Posted : 20/12/2011 9:50 pm
 CHB
Mines on its way! Sent yesterday and currently in the local depot of the couriers.
Posted : 21/12/2011 7:44 am
Mines at the sorting office
Thought I'd missed out!
Posted : 21/12/2011 10:20 am
Just delivered:)
Posted : 21/12/2011 11:15 am
Just ordered a Garmin Edge 500, but can't collect it until 29th Dec.
BOO!!
Something to look forward to once I have opened all my pressies though!!
Posted : 21/12/2011 1:10 pm
Ordered the 800 Monday might and it just arrived, even though I didn't pay for quick delivery. Superb.
Big thank you to CP and Frogstomp for the code tip.
Posted : 21/12/2011 2:25 pm
Mine has just arrived as well, brilliant deal so thanks for the heads up from the OP and for the extra discount code as well.
One question I now have - I've registered the device on My Garmin, but when I try to register the maps, the option for Garmin GB Discoverer - All of Great Britain isn't there in the list, although there are lots of other options. Anyone else had this problem, and if so how did you get round it?
Posted : 21/12/2011 6:41 pm
Excellent find!
Just received an 800 with the discoverer maps (OS).
Anyone any idea if you can replace the duff basemap with open street map to get more 'sat nav' style mapping for road use?
Posted : 21/12/2011 6:44 pm
 Alex
I got the Navigator bundle as I have OS maps already and wanted sensors without having to order them from someone else. Very nice looking bit of kit. I think talkytoaster might have what you need clowner.
Posted : 21/12/2011 7:17 pm
Clowner. If you've got the OS maps enabled just set the unit to read in automotive mode. It will look just like a car sat nav, with all roads/streets and POI's etc.
Posted : 21/12/2011 7:28 pm
How do you set it to automotive mode?
I've set the routing to car/motorbike as thats all I can see that would be similar but it hasn't changed the map.
Have figured out how to load custom maps using Mobile Atlas - loaded Google earth photos for local area. Very impressed.
Posted : 21/12/2011 7:40 pm
Page 2 / 3
