Advent Offer: Day 1
Save 50% on ALL brake pads, including finned pads, with code XD1.
Only available on 1st December 2017!
Good PSA. Unfortunately out of stock of S5 shimano pads, as they have been for months. I have heard they are getting out of the pad business
No useful stock though 🙄
Useful for me though - thanks!
only valid on 4-packs
They don't even list a suitable pad for my Hope E4's 😥
The 4 packs are great value and you can mix and matchonly valid on 4-packs
Don't look to be any Shimano S5 pads in stock in Kevlar, organic or sintered. Same last time I needed pads a couple of months ago.
How are the finned pads then?
An abundant pain in the hoop to fit - the fins and pads are separate from each other, gave up and dropped Shimano pads in. Took 2 minutes.
Ive got some finned ones to replace XTR ones and they are fine. They fit in the caliper and they stop me. Not sure I'm rad enough to justify the extra cooling of the fins cos my other brakes work fine too.
no one seems to have any hope e4 pads atm.
Have you had the 2nd email yet ? 😆
The M4 pads should work in E4's. Not as big a pad surface area, but I think the backing is the same size.
is that still happening? Needs better glue 🙄50% off
Currently running M4's as a stop-gap in the rear and they sit wrong against the pistons, twisting slightly. Just picked up two pairs of Hope Sintered from the LBS so I'm swapping the M4's out before tomorrow's ride.
Cheers OP.
Just picked up 2 full sets of MT Trail pads for £12. Bargain considering the fronts require 4 pads each.
Thanks, glad I like old school S1 pads
