probably another du...
[Closed] probably another dumb fork servicing question
3 Users
can i change the oil in my motion control damper without removing the fork lowers ?
Posted : 14/08/2010 1:18 pm
Yep, undo cable (if you have pop loc or push loc), use a spanner (15mm I think) or adjustable to undo the damper, be careful not to gouge the crown and have patience it's quite a fine thread.
Once out turn the forks up side down and drain out oil, replace with fresh, oil weights and measures can be found on teh RS website.
Posted : 14/08/2010 1:30 pm
thanks!!
Posted : 14/08/2010 1:32 pm
Oil needs to be measured pretty carefully from experience. You can get large syringes from photo developing shops. and there is a washer on the top of the damper which can pinch when you put it back, in so wiggle carefully.
Posted : 14/08/2010 4:01 pm
