PRESS FIT BOTTOM BR...
[Closed] PRESS FIT BOTTOM BRACKETS FOR A ON-ONE WHIPPET......HELP!!!!!!!!!!!!!!!
Hi I ride an on-one whippet but i currently have problems with the bottom bracket and now have decided to replace it. I believe the frame takes a BB92 bottom bracket and i am running Shimano XT hollowtech 2 cranks. Does anyone recommend a good high quality BB?
Posted : 21/02/2012 1:15 pm
On One have A Token red one for £20 reduced from 50.
http://www.on-one.co.uk/i/q/BBTOKBB92/token_pressfit_bottom_bracket
HTH.
Posted : 21/02/2012 1:23 pm
Cooie, that’s what i have fitted. After 5 rides it started clicking so i stripped it down at the weekend and the bearing seem to be gritty. Do you have any ideas of other bottom brackets?
Posted : 21/02/2012 1:36 pm
You may find on-one will tell you not to use anything other than a plastic shimano one...
There seems to be a little stretching taking place within the bb shell with those types of bb. When you think its worn out, its actually not, it just is loose within the frame 😯
Posted : 21/02/2012 1:42 pm
No idea of any issues specific to whippets but of the BB92's I've tried in my zesty (shimano, KCNC, enduro fork seals), the Enduro Fork Seals has been my favourite by a county mile:
http://www.enduroforkseals.com/id258.html
About £60 and takes a couple of weeks to ship from the states though.
Posted : 21/02/2012 1:49 pm
I was just about to mention the Enduro one! Worth it if you can afford it.
Posted : 21/02/2012 1:51 pm
I do get a bit worried about the bb on my whippet, easy to replace but maybe a bit too easy?? At what point will it become a little less snug and become sloppy? My KCNC one has been OK so far for a few months. Would be interesting to hear how other folk are faring now that there are a few more whippets in circulation
Posted : 21/02/2012 9:26 pm
 DT78
If you are worried about fit could you just run a layer or two of duct tape on the bb to make it snug?
Posted : 21/02/2012 10:27 pm
Not sure duct tape will do much for longer than a few minutes??
I have been using the plastic Shimano BB in my Whippet for about 3 months now. It's beautifully smooth but...the drive side shell is looser than the other in the frame. When dismantled the loose shell binds with the crank spindle where it flares a little near the joint with the spider, as opposed to staying put in the frame cup. This doesn't cause any pressing issue (except a bit of creaking) but i am a bit concerned re this moving of the shell in the frame cups damaging the frame over time as the BB moves about slightly.
I have discussed this with On One and, as my only real issue currently is some creaking, they have just reassured me the frame is warrantied for 2 years. Seems fair enough as long as i'm not replacing BBs every few months.
Posted : 21/02/2012 11:12 pm
