Have put on a bit of weight recently. So I need LESS rebound damping, right?
Posted : 12/09/2022 4:55 pm
You need more pressure, and consequently more rebound.
Posted : 12/09/2022 4:59 pm
More spring pressure and More rebound damping. - beaten to it by Ben!
Assuming you've put more air in your fork then you'll want more rebound damping.
More air = higher spring rate so more natural rebound force.
Adding some rebound balance it out.
Although in my experience if you've gone up 5-10psi you shouldn't need to change much / far
Posted : 12/09/2022 5:00 pm
Magic, thanks all.
Posted : 12/09/2022 5:02 pm
As above.
Interesting thing, compression damping is all about what, where and how you ride. Rebound damping is just about the force the spring is generating.
Posted : 12/09/2022 5:04 pm
