Post Mount Standard...
[Closed] Post Mount Standard Dimension
5 Users
I need a drawing showing the standard dimensions of a rear Post Mount brake mount for a standard 160mm rotor.
ie dims from wheel axle and inside face of the dropout.
Can anyone help?
Posted : 17/11/2010 10:54 am
no-one knows where to look?
Posted : 17/11/2010 10:21 pm
Had a couple in the shop recently, if I get a chance later i'll measure one up(no promises though.)
Posted : 18/11/2010 7:27 am
Does [url= http://service.foxracingshox.com/consumers/Content/Resources/pdf/2011_Fox_32_USER_SPEC_RevA.pdf ]this[/url] help at all. I know that it is for the the front fork but I imagine that the spacings would be the same or you could measure to verify.
Posted : 18/11/2010 7:37 am
On [url= http://www.hayesdiscbrake.com/support/ ]this[/url] page they have
INDUSTRY STANDARD MOUNTS
1. Post Mount
2. Front IS
3. Front 20mm IS
4. Rear IS
5. Rear Installation IS 160mm
6. Rear Installation IS 180mm
7: Hubs
but oddly no rear post mount drawing. Probably because the rear is the same as the front but rotated any amount you like.
Posted : 18/11/2010 9:42 am
Rear post mount is quite rare isn't it?
I have it on both of my Salsa's but even they i think have gone back to IS mount now. Shame, it's quite neat.
Posted : 18/11/2010 9:47 am
Brilliant, thanks Nicknoxx.
I'm getting a new pair of sliding dropouts made to try and cure my belt-drive issues, so i thought I might aswell incorporate the post mount on the non-drive side.
i think that on the whole its not cost-effective to include post-mounts on "normal" frames - much cheaper to machine IS mounts and bolt an adaptor in. But it should look a lot neater.
Posted : 18/11/2010 10:20 am
Might be a good idea to put a tension screw like the new dropouts have:-
Posted : 18/11/2010 12:53 pm
That looks exactly like the one I've drawn, but I've repositioned the bolt holes to allow an extra couple of mm in "chainstay" length so i can get a bit more tenion.
Posted : 18/11/2010 4:26 pm
