Forks take 180mm disc with no adaptior
203mm icetec rotor
My 20mm post to post doesn’t fit.
Which post adaptor do I need? Ideally not an expensive Hope one.
Advice much appreciated
You want a 203 ppm (yours will be a pp2). There’s two versions a standard and Xtr if your buying a shimano one. The standard is fine and half the price.
If you have Hope brakes (possibly only the four pot calipers) Hope may be your best choice as the calipers don't fit many adaptors, they foul the centre section
Thank you for both your replies,
I Should also point out that you can almost certainly just shim out your caliper with 1.5mm of washers and it will be fine, no-one will die.
