pinch up bolts on 2...
[Closed] pinch up bolts on 20mm forks
Hi all just wonderd if anybody has had any problems with pinch bolts on 20mm bolt up forks with them cracking and can you still use them .It hasnt cracket all the way round can any body shine any light on this for me im a bit worried in riding it tomoz
Posted : 15/03/2012 10:00 pm
Is it the bolt, or what the bolt screws into?
Bolt is cheap to replace. Bit it screws into -maybe not so cheap! Some forks come with replaceable steel inserts there as the magnesium casting is fragile: threads strip under less bolt torque/tension, and it allagedly cracks easier than aluminium or steel.
Posted : 15/03/2012 10:12 pm
It happens when the bolts are over-tightened (they only need a wee nip up). Depends on the fork and your luck really when it comes to riding on them now.
36s or older Marzocchis by any chance?
Posted : 15/03/2012 10:23 pm
Crack is well dodgy - photos to see if its crucial
Posted : 15/03/2012 10:25 pm
seem to remember this happening a lot a while ago, maybe to older fox's ?
Posted : 15/03/2012 10:26 pm
They are manitou minute pro forks 2011 -2012 the crack is left to right on the face plate in the corners i was told to put a shim in the pinch slot iv looked on other sites where people said yes it will be fine or no it seems to be a common thing
Posted : 15/03/2012 11:12 pm
