Pike select charger...
[Closed] Pike select charger damper no effect after airshaft change?
I've put a 160mm debonair airshaft in a fairly new Pike select and now the charger damper is having little or be effect when I turn the dial.
Previous to the airshaft change turning the dial would stiffen the fork up but now it's having no effect.
Damper side wasn't touched on airshaft change ?
Any ideas on what it could be ?
Posted : 31/08/2020 5:54 pm
ahem can I tag along with this thread?
I replaced mine with a longer travel airshaft (same spec) but have had to put a load more air in than before, feels absolutely fine but am slightly concerned something ain't right?
Posted : 31/08/2020 6:17 pm
You'll need a lot more air than normal - that's an affect of the debonair shaft.
Lack of damping.... You may have blown a seal, or let some air in. Typically first step is to give the damper a bleed.
Posted : 31/08/2020 7:17 pm
Nah, it's just ice cream...
Posted : 31/08/2020 7:23 pm
