PeterPoddy - rocksh...
[Closed] PeterPoddy - rockshox servicing guidee is it?
where want to service my pikes
Posted : 19/05/2009 8:32 pm
Email him, he's a very nice chap.
If you can't get hold of him then mail me for the poplock removal article he did, it includes basic service instructions.
Cheers.
Posted : 19/05/2009 8:54 pm
undo bolts about 5 mm then tap them with a rubber mallet to free the rods from the lowers , allow old oil to drain
gently pull lowers from stanchions
pull out foams from under wipers
clean inside forks with isopropyl alcohol
soak foams with 15wt oil
gently put them back into place under wipers
put small amount of grease under wipers
push lowers back onto stanchions (carefully) until they're about 50% home
hold forks horizontally and use a syringe to squirt 15ml of oil into each leg
do bolts back up on bottom of forks
go ride
(picture guide [url= http://www.cycletherapist.co.uk/step-by-step-guides/rock-shox-lyrik-lower-service/ ]here[/url])
Posted : 19/05/2009 9:31 pm
cheers retro bit that is only a lower oil change, i menat the dampers and rebound circuit
Posted : 20/05/2009 7:01 am
I got an email last night from someone asking for them....
I was out riding all night and now I'm at work, and they're on my PC at home. I'll email them through tonight when I get home....
๐Ÿ™‚
Posted : 20/05/2009 7:08 am
Ah no worries, PP would you possibly be able to put the guide on the web again?
Posted : 20/05/2009 8:05 am
thanks pp
Posted : 20/05/2009 8:41 am
I take it you mean something other than one of these?
http://www.sram.com/en/service/rockshox/view.php?catID=1&subcatID=5
Posted : 20/05/2009 9:10 am
[i]I take it you mean something other than one of these?[/i]
I preferred PPs though. Use to have his bookmarked but lost them when AOL stopped hosting. Any chance I could get the guides PP?
Posted : 20/05/2009 9:14 am
Ah right he did his own version? I would quite like to see that - I have somewhere I could host it in fact if someone sent it to me.
Posted : 20/05/2009 9:17 am
Anyone who wants one, email me.
I don't have the time or the skillz to get them up on the web again. AOL stitched me up like a kipper. Gits.
๐Ÿ™
Posted : 20/05/2009 10:09 am
