Pedal Bearing Remov...
[Closed] Pedal Bearing Removal - any DIY methods/Tips?
8 Users
I don't have a bearing pulling tool - and I want to replace bearings in my spank spikes - thinking of trying to gouge / 'hook' them out .. Anyone done this ? Not bothered if bearings get damaged as I've got new ones to fit .. Rummaging around tools to find a 'hooking' device right now ..
Posted : 18/06/2016 11:39 am
You'll be bothered if the inner race comes out leaving the outer in.
Just get the tool and get it out straight.
Posted : 18/06/2016 11:52 am
Anyone? I'm a sucker for a bodge job !!
Posted : 18/06/2016 12:17 pm
You might be able to get the bearing out if you carefully tap the inside race on alternate sides with a long hex key, from the outer side? Getting in to the pedal body seems a bit difficult due to the shape of the pedal body though. If that doesn't work you could possibly bodge a blind puller with an expanding anchor nut and bolt from a DIY store, I've used that method in the past with similar scenarios. In the end though I just bought a blind puller set for stuff like this.
Whatever you do you need to get the bearing out straight. If you just try to gouge or lever it out with brute force from the inboard side you are almost certainly going to **** your pedals.
Posted : 18/06/2016 12:43 pm
try freezing the pedal for an hour then pouring boiling water over the area where the bearing sits, this may help you remove the stainless bearing.
Posted : 18/06/2016 3:19 pm
Blind beating pullers are cheap. Get one. 🙂
Posted : 18/06/2016 4:47 pm
Or find the right size Rawlbolt
Posted : 18/06/2016 4:58 pm
Posted : 18/06/2016 8:50 pm
Might seem weird but a rawlplug bolt would do the job.
Posted : 18/06/2016 8:55 pm
