Pace fork seals
[Closed] Pace fork seals
[#2831926]
Following a thread earlier about how good pace forks are, I have been pulling mine apart getting ready to replace the seals.
Firstly, I am going to make a tutorial for pulling the forks apart including removal and cleaning of the damper and spring assemblies.
Secondly, I am looking for a supplier of seals other than direct from pace. I have found 2 possible options but still have to take measurements of the old ones.
Please could people let me know what interest there would be for either of these. I wouldn't be trying to make money just aiming to get alternative products for other members on here. If this is against forum rules then please could a mod let me know.
Thanks
Mark
Posted : 08/06/2011 10:43 pm
Get in touch with Retrobike members..
Posted : 08/06/2011 11:23 pm
Have a set of 2k evo 3 forks that need work so I'd be keen on hearing more. Saying that pace will do the whole fork for 90 quid...
Posted : 09/06/2011 6:50 am
Google Fork English. The chap, Tim, has a very good rep.
Posted : 09/06/2011 8:37 am
*puts hand up*.
I usually send mine to Tim at Fork English - good service - but, as with all bike-related jobs, would be interested in learning how to do this myself.
Posted : 09/06/2011 10:47 am
Fork English here too.
Although I think he probably just gets his seals from Pace like everyone else, tbh.
Posted : 09/06/2011 10:48 am
Thanks for the pointers guys. Have emailed him.
What Im more interested in is trying to help anyone who wants to service their kit at home but also without having to spend a fotune on parts due to how often they have to be stripped.
Posted : 09/06/2011 10:50 am
Don't know if you are still checking this thread but i just bought a set of worn RC 39's and are keen to rebuild them myself so would be interested in any information you have found out.
Thanks
Posted : 31/10/2011 10:05 pm
I may be interested in ones that fit rc40s. The set of my commuter could do with a service.
Posted : 31/10/2011 10:10 pm
I am also looking for new seals for my RC39s - last time I checked seals from Pace were something like £40 so if you can source them elsewhere I'd be interested.
The ones on at the moment have a Pace logo on them so I suspect they might be an odd size, but I'm no expert.
Posted : 31/10/2011 10:18 pm
You may be able to source them from your local branch of Sealmasters.
Posted : 01/11/2011 1:38 am
I emailed MarkyG82 as this tread was started a while agoe. I have copied the information he kindly provided me with below for others to benifit from.
2 x 32x40x10mm Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R23 / TC (32x40x10_TC) = £10.36
These are the the seals I used. Got them from simply bearings. Google for them. They were very helpful when I rang them. The sealant I used was high performance plumbing adhesive type stuff. Any sealant will work I think.
One quite important tip I can give is to smear the stancions with fork oil before fitting back in the lowers. Stops them from sticking to the bushes and wearing out too quickly. I learnt this a few years ago and do it on every fork I pull apart.
Posted : 01/11/2011 11:10 am
Cool, thanks for the info.
Did you have any issues getting them to fit?
What was the plumbing sealant for?
Posted : 01/11/2011 11:17 am
To stick the foam o rings/seals to the inside of the carbon lowers.
Posted : 01/11/2011 11:32 am
+1 shindiggy
In the distructions it say you have to use silicone sealant to fit the seals in place. This is due to the carbon lowers not having any 'lips' to hols the seal in place. As they are being help by sealant, the slightly smaller size can be used as the gap is filled up by gunge.
I used plumbing stuff as its a better quality than bathroom/kitchen sealant and also had some on the shelf. The hardest bit was getting the seal at the right height due to there not being a lip on the outside stopping it from dropping.
Posted : 01/11/2011 12:50 pm
Cool, thanks.
Posted : 01/11/2011 1:30 pm
MarkyG82 - did you ever do the tutorials you mentioned in the first post?
Could do with a clearer explanation on servicing RC40XCAM than is available in the manuals.
cheers.
Posted : 01/11/2011 1:43 pm
When the spanners came out, I totally forgot to take pics as I took them apart. When I get time later Ill do a written tutorial with referance to the Pace one. That way I can describe what the Pace guys are on about a bit clearer.
PS. Bike is at my brothers so cant even get pics in the current state :O
Posted : 01/11/2011 2:05 pm
