those little washer...
[Closed] those little washers you find in shimano bash guards....
[#2832067]
those little washers you (should) find in shimano bash guards.... where from?
have been given a bash but the tiny, thin washers are missing and the bolts pass through the bash...
cheers
Posted : 09/06/2011 12:29 am
I had a "quest" for these last year and failed. I ended up making my own from some hard frame nylon (?) pivot bushes from a k2 razorback. Sorry if thus doesn't help but the official line is that they shouldn't come out so are not available as spares. Even my local bearing and washer manufacturers couldn't help.
Posted : 09/06/2011 1:25 am
please post again if you find them, i've got the same problem.
Posted : 09/06/2011 6:58 am
on CRC they have specific chainring bolt for a bashguard from Raceface. i'm not sure if the Raceface bolts are specific to Raceface bashguards....
i can't tell from the picture whether the head on the bolts is a little larger.
there are also bolts from E-13 that might be specific to use with a bash. i don't know.
if some one is able to compare a Shimano and Raceface bash it'd be helpful...
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=5995 ]E-13 bolts[/url]
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=46947 ]Raceface bolts[/url]
Posted : 09/06/2011 12:23 pm
Can't you just fit a normal washer?
Posted : 09/06/2011 12:31 pm
no.. these things are tiny. the normal bolt passes through with just a hairs width to spare.
Posted : 09/06/2011 12:32 pm
