P7 rubber 0-ring fo...
[Closed] P7 rubber 0-ring for mounting
[#195042]
Does anybody what/where o-ring I need for securing a P7 torch to the handlebar ? I've already got a lockblock but would like to reduce the shakes even more. Thanks.
doglover
Posted : 06/01/2009 8:32 pm
 GW
just use this mount.
[url] http://www.dealextreme.com/details.dx/sku.15642 [/url]
Posted : 06/01/2009 8:41 pm
Been using O-ring's from inside a 40mm push fit plumbing connector, T/Y (depends how you look at it) junctions have 3 in them. I pinched mine from a plumber at work 🙂 yes he knows as wouldn't want anybody to have a leak.
On oversize bars they fit nice and tight with no wobble at all, if your on standard size bars maybe try a 32mm.
so maybe a plumbers merchant. You should be able to just get the O-rings.
Carl
Posted : 06/01/2009 8:48 pm
Pack of large o rings from B&Q £2.00 - ideal fit.
Posted : 06/01/2009 8:51 pm
Thanks just what I needed to know, will check out my local plumbers store.
Posted : 06/01/2009 8:55 pm
