Oval chain rings &a...
[Closed] Oval chain rings & dinner plate cassettes, a Q about tension.
So, yet again I have changed my bikes about bit to try & make me get out more, it probably won't work but I still like spending my down time messing with my bikes & trying things ๐Ÿ™
So I bought into the 1X 10, oval ring & massive cassette thing, I'm not using a clutch rear mech & should you back pedal in the lowest few gears the chain wants to go backward with it, would you run more tension than this on the rear mech?
[url= https://c1.staticflickr.com/8/7673/27761552960_8a58ea4f35_k.jp g" target="_blank">https://c1.staticflickr.com/8/7673/27761552960_8a58ea4f35_k.jp g"/> [/img][/url][url= https://flic.kr/p/JicduQ ]Untitled[/url] by [url= https://www.flickr.com/photos/94658862@N08/ ]Martin Robbo[/url], on Flickr
I recon I could get another link out of the chain with a little wriggle room but the mech will be pretty stretched, is this normal?
Cheers.
Posted : 02/07/2016 7:43 pm
I know nothing about this stuff, but like you, I made the switch to 1x10 fairly recently. I have much less tension than that, no clutch mech, just a Hope narrow-wide, and it's been fine.
Posted : 02/07/2016 7:46 pm
 DanW
Yes it's normal, more chainline related than anything. Fewer links won't help IMO. Why are you back pedalling in the granny gear? ๐Ÿ™‚
Posted : 02/07/2016 8:41 pm
Pic is of max tension, problem is with the lowest sprockets ๐Ÿ˜€
I forgot to add that I had to put three spacers on to the drive side so the ring clears the frame, is that OK?
Cheers.
Posted : 02/07/2016 8:57 pm
Didn't really have a problem with tension on a Zee/40t with an Oval 34t on the FS.
Set the B-Tension to 6mm between the jockey wheel and largest cog.
What I did find the cassette "worn" quicker as the teeth couldn't engage enough.
Posted : 02/07/2016 9:04 pm
Is the chainring on the inside or the outside of the spider?
Posted : 02/07/2016 9:40 pm
inside, it's for 94 BCD FSA cranks so comes with the spacers moulded on to the ring.
Posted : 02/07/2016 10:21 pm
I'm tempted to just sell the cassette & go back to 11-36, I just think it looks weird ๐Ÿ˜•
Posted : 02/07/2016 10:33 pm
