Any recommendations that keeps the chain relatively clean?
I like White Lightning Epic which I have used now for a couple of years. Seems to keep the chain a alot cleaner than the Finish Line stuff I was using prior to that.
Seems like quite a few people are "raving" about Finish Line Pro Road but you will need to keep on top of cleaning the drive chain
Finish Line Pro Road rocks.
Anyone used Rock n roll lube?
Another impressed user of Finish Line Pro Road.
Oil or lube doesn't keep the chain clean, cleaning it does. Sorry, that's not meant to be controversial, but I'm sure we've had the waht lube Q before and I think lube is just lube.
You couldn't be more wrong: Some lubes attract more dirt than others. Finish Line dry lube, for example, doesn't attract as much dirt as the wet version, but gets washed off easily.
