what are there out there to attach a rack, can you get a 30.0mm seat posrt clamp with rack mounts and p clip on the stays at the bottom? or is there a better solution
Seatpost mounted rack? I wouldn't trust my tescos one with much weight, then, I wouldn't want to carry much weight on a rack anyway.
tis for the commute so at least 1 pannier a day sometimes 2 seatpost rack not a viable option
SJS cycles do this [url= http://www.sjscycles.co.uk/category-Other-Rack-Accessories-255.htm ]HERE[/url] . Might be what you are after.
Don't know for sure whether you can get the seatpost clamp with rack mounts in that size - bit of a strange size - but the 28.6 one I've used on my hardtail does the job.
As for the bottom end - this might be worth a look: [url= http://www.sjscycles.co.uk/product-Tubus-Tubus-Disco-Rear-Cycle-Rack--For-Bikes-with-Disc-Brakes--For-26in-700c-Wheels-17364.htm ]Tubus rack[/url]
HTH
I used p clips on my old Rock Lobster, rode across some of Dartmoor then 3 days of road riding. Seemed secure. Panniers weren't full though.
456.?
Er sorry.
A 30mm seatpost will probably be a 31.8mm clamp, like the one on SJS website.
my mate got an old man mountain rack (with p-clips) from carradice on his soul.
works pretty well; and took 40lb on our SDW trip!! ๐ฏ
I fitted one of [url= http://www.axiomgear.com/products/gear/racks/rear-racks/odyssee-disc/ ]these[/url] to a bike with no fixings by the dropout. However, it does need some mounts by the saddle. You would be able to use one of those seat clamp / mounts things with it. It has the advantage of being compatible with disks.
They also do a range of racks that make use of the QR - [url= http://www.axiomgear.com/products/gear/racks/ ]have a look here[/url]
midlifecrisis did you buy the rack from the states or in the uk?
That Tubus looks neat but think you'd struggle a bit with the Soul's cowled dropouts?
Here's another idea don't know anyone that uses one as yet but will be getting one myself later in the year.
tubus do various fitting kits for bikes with no mountings.
I got the Axiom from [url= http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=14332 ]CRC[/url]
It presented no problems on an 8 day tour of Mayo and Galway:
