One up v2.1 dropper...
[Closed] One up v2.1 dropper actuator on a V1 post?
Hello
Has anyone fit a OneUp V2.1 dropper actuator on a V1 post? My Bird AM9 is getting bad cable rub from the way the V1 post pulls the outer and not the inner cable. I don't see why it wouldn't work but I want to check before I order it.
I've emailed OneUp a couple of times and got no response, they also don't respond to comments etc on social media channels.
Posted : 18/05/2021 9:04 am
I don't think it's possible... very much want someone to show us otherwise though!
Posted : 18/05/2021 9:16 am
I asked OneUp that exact question a month or 2 back and they said it's not compatible - annoying as the internal cable guide on my frame is a touch longer than I expected so at the ideal insertion depth it can interfere with the actuator meaning I get a slightly saggy post, so I end up running it a couple of mm higher.
Of course if you decide to see if it's bodgeable I'd love to know the outcome!
Posted : 18/05/2021 9:22 am
I've done it, because I didn't realise it was a v1 on my second hand bike! Didn't work at first but filed the actuating rod down a bit and has worked fine for a year.
Posted : 18/05/2021 9:57 am
Top bodge! Did you take any photos to help others understand the modification?
Posted : 18/05/2021 10:01 am
Didn’t work at first but filed the actuating rod down a bit and has worked fine for a year.
Ahhhh - how much filing and swearing was involved? With hindsight is it a 5 minute job with a dremel???
Posted : 18/05/2021 10:02 am
Basically when I installed it the post wouldn't quite stay up, as if I was slightly pressing the actuator even though the cable was slack. So I carefully filed a bit off the long thin actuator rod. Then checked it, then filed a bit more. I was obviously worried about filing too much so it was a slow iterative process. I think you'd have to do the same as tolerances might mean my filing amount wouldn't work for you. I'm a bit worried one up saying it isn't compatible meant I got lucky in some way. Works for me though.
Posted : 18/05/2021 10:17 am
I didn't actually do it in the end (decided to swap it for a longer drop one) but that was also what I decided would probably be the solution.
Posted : 18/05/2021 10:53 am
Hmmmmm.... tempting. But not until after my week away in June! I guess if it all goes horribly wrong I can just get a replacement V1 cartridge so the price of ham fisted stupidity is 50 quid + P&P
Posted : 18/05/2021 11:00 am
