I'm running a 32 / 16 on my inbred slider and looking to experiment with different sprocket size. I took the wheel to my LBS to get a tool to remove it, either my LBS is a donut or the on-one sprocket requires an odd removal took. Any of you fine chaps removed a sprocket from an on-one single speed hub - I'm looking for a tool rather than a hammer and drift approach, thanks
If it's the one they usually do, there is no tool - hammer and drift is the best way. FOr some unknown reason (i.e. it was dirt cheap) they specced a freewheel with no tool engagement points
as nbt if it's the dicta freewheel they were fitting a few years ago.
sorry.
Cheers nbt & Del, yes it's a few years old, I'm planning on going back to S/S for the winter - I guess hammer and drift to remove and then purchase a free wheel from elsewhere thaty has a suitable tool.
Any suggestions for replacement - I'm guessing I will end up with a selection of freewheels to try until I find my single speed mojo - thanks
I have run the £16 shimano jobbiesand the £6 "proper" dicta jobbies. Both ok, you get what you pay for though, the shimano last longer. Not shelling out £40 for a white industries though.
yeah, unfortunately it's just a case of try and see. do you want to go quicker spinning or pushing harder?
