On-One inbred slidi...
[Closed] On-One inbred sliding dropout brake problem
 taka
[#1865274]
Hi,
ive Just started to build up one and the rear brake calliper is too close to the frame and it bends the disc when i start to tighten it up am i missing something?
tom
Posted : 05/08/2010 5:05 pm
IIRC mine came with spacers for the mounting bolts.
Posted : 05/08/2010 5:06 pm
Also, setup the brake side tensioner to pull forward.
You'll see why if you don't 🙂
Posted : 05/08/2010 9:59 pm
What al said. You need spacers. Assuming that you do mean sliding not slotted
Posted : 05/08/2010 10:06 pm
My second hand Inbred frame didn't have the rear caliper spacer so i bought some longer mounting screws and went looking for something to act as a spacer...
Turns out the inner part of a chainring bolt is just long enough to sit between the frame and the brake adaptor and act as a shim.
Posted : 05/08/2010 10:14 pm
I used the concave and convex washers from some V brake pads on mine - work a treat. If you get realy stuck I might have some hanging about.
Posted : 06/08/2010 11:05 am
 taka
Cheers ive managed to get some spacers the same as Hicksy but ive now found ive bent my flaming rotor!
Posted : 06/08/2010 12:39 pm
 taka
epicyclo how do i do that?
tom
Posted : 06/08/2010 12:41 pm
taka - Member
Set it so it is pulling forward, ie mount it so the tension screw is bearing on the front. The rhs one points back, this one points to the front.
The reaction of the disk brake pulls the sliders backwards on the left side and this prevents that.
I don't have a photo, but if you can't see how to do it I'll pull the frame out of the attic and take a photo to show how to do it.
Posted : 06/08/2010 1:54 pm
 taka
cheers ill have a go when i get home
Posted : 06/08/2010 1:56 pm
Here you are -
Chain side:
[img] http://www.flickr.com/photos/34903211@N02/4865465355/in/set-72157624540994313 [/img]
Brake side:
[img] http://www.flickr.com/photos/34903211@N02/4865465021/in/set-72157624540994313/ [/img]
Edit: can't see the photos - new Flickr page - what am I doing wrong?
[u][b][url= http://www.flickr.com/photos/34903211@N02/sets/72157624540994313/with/4865465021/ ]Anyhow, go here[/url]
[/b][/u]
Posted : 06/08/2010 2:21 pm
 taka
cheers i see what you mean now ill have a go when i get home
Posted : 06/08/2010 3:33 pm
I wouldn't stress about the LHS
Posted : 06/08/2010 3:35 pm
Neither of my brake side ones have ever moved.
Posted : 06/08/2010 3:39 pm
Mine hasn't moved ever in 5 years of ownership. Second the v-brake spacers as a substitute.
Posted : 06/08/2010 4:09 pm
Mine moved several times. No amount of tension on the slider bolts would hold it.
This stopped it.
Posted : 06/08/2010 4:16 pm
You a bit of a chubber?
Posted : 06/08/2010 4:19 pm
My missus reckons I have a fat head... 🙂
Posted : 06/08/2010 11:33 pm
