I am thinking of getting a Codeine but cannot decide on which size.
I am about 5'8 ish so fall right between the small and medium anyone got any real world sizing experience, i currently ride a 2012 medium Nukeproof Mega
It depends on how tight you like the cockpit. I'm the same height as you, but I have A 32" inside leg and I'm +6" ape index, so short in the body. The small is the one I would choose. I ride a medium Meta SX with a50mm stem and my road bike is a 55cm with 120 stem.
If you want one to throw around, go small, if you want one to 'ride on' get the medium.
Personally, at almost the same height as you, I'd like the reach/eTT of the medium but the seatube length of the small. These days I want to run a dropper but, on the medium/18", there wouldn't be enough difference at normal ride height between the top of seat tube and saddle to run a 125mm dropper. If pushed I'd probably take the small
Thanks guys, i had come to the same conclusions myself. If any one out there has ridden one then i would appreciate there input
