OK to run 10 speed ...
[Closed] OK to run 10 speed deore rear mech with 105 10 speed sti shifters?
 SiB
I'm assuming its OK but could just do with a knowledgeable nod (or otherwise) before the work commences, thanks
Posted : 05/01/2017 11:09 am
Only using something like the [url= http://www.wolftoothcomponents.com/products/tanpan ]tanpan[/url] which changes the pull ratios as MTB 10 speed and road 10 speed have different pull ratios, you can use a 9 speed MTB rear mech though as that has the same pull ratio as 10 speed road
[img] ?v=1469122334[/img]
Posted : 05/01/2017 11:11 am
 SiB
I'm glad I asked, so much for my assumption!
Thanks oliverracing
Posted : 05/01/2017 11:15 am
No problem, I run these on all my drop bar bikes in both 10 and 11 speed guises, one thing that can be good to know - 10 and 11 speed shimano MTB rear mechs are completely swappable in terms of pull ratio, so all you have to do is match the road shifter to the cassette and tanpan (all 10 or 11 speed) and you are free to use whichever MTB 10/11s shimano rear mech you have lying around
Posted : 05/01/2017 11:20 am
You could use a 9speed Deore mech with no adapter
Posted : 05/01/2017 11:27 am
scotroutes - Member
You could use any 9speed MTB [s]Deore [/s]mech with no adapter
FTFY
Posted : 05/01/2017 11:37 am
 SiB
thanks again
Posted : 05/01/2017 12:18 pm
bigyinn - Member
scotroutes - Member
You could use any 9speed MTB [s]Deore[/s] mech with no adapter
FTFY
Strictly Scotroutes is more correct.
Deore, Deore LX, Deore XT (is it still called Deore XTR?) all work.
Any "MTB" (including SRAM) won't work, because SRAM used a 1:1 ratio.
Anything Shimano older then 9 speed will work too (I've got old XT mechs on my tourer).
Posted : 05/01/2017 1:12 pm
What I meant was Shimano 9 spd, obvs. I don't think XTR was ever prefixed with Deore, although I stand to be corrected.
Posted : 05/01/2017 4:23 pm
