Ok I'm going t...
[Closed] Ok I'm going to ask a really stupid question!
Is it possible to fit a tapered fork steerer in to a frame only designed for a 1.1/8?
I think I know the answer!
Ta
Posted : 07/09/2013 9:48 am
no
Posted : 07/09/2013 9:49 am
Sometimes! You can get a Cane Crek XX 44mm (IIRC) headset to do it if your frame has an internal headset.
Posted : 07/09/2013 9:50 am
As above, if the frame is designed for a external 1 1/8 headset you can not fit tapered forks, if however the frame is designed for an internal 1 1/8 headset you can buy an external cup for the lower race and fit tapered forks.
Posted : 07/09/2013 9:54 am
What njee said- what frame is it?
Posted : 07/09/2013 9:59 am
Thanks guys. New frame it is then ๐Ÿ˜€
Posted : 07/09/2013 10:15 am
Banshee Paradox Mk1. It's almost impossible to find a reasonably priced set of 29er forks with a 1.1/8 steerer and 20mm bolt through axle as my Minutes have given up the ghost ๐Ÿ™
Posted : 07/09/2013 10:17 am
 akak
There is a Banshee forum on mtbr which you may find useful? If your wheel could run as 15mm that would give you a wider choice.
Posted : 07/09/2013 11:50 am
