Ohhhhh nooooo! RS P...
[Closed] Ohhhhh nooooo! RS Pike brake mounts have caught me out!
So today is the day ive finally had some downtime to get my new forks on. Just finishing up and looking forward to a ride, then bam. First and only problem. I run a 203mm front brake and on the previous RS Judy had the correct Shimano 203mm post mount to compensate for this. Fitted it to the Pikes and the caliper now sits too high on the disc. Pads are only covering approx half of the disc if that. So what adaptor do i need? Thanks in advance
Posted : 02/05/2021 5:41 pm
You need a +23mm, we've got XTR ones on 2 bikes with Pikes.
Posted : 02/05/2021 5:43 pm
Don't suppose you have the shimano part number do you @fathomer?
Posted : 02/05/2021 5:59 pm
XTR SM-MA90 I think but a quick Google suggests you might be out of look with stock. I got one in January from wollyhatshop.
Posted : 02/05/2021 6:04 pm
Does the caliper mount direct to the adaptor or is it the longer bolts through the adapter as a spacer?
Posted : 02/05/2021 6:09 pm
You can use any compatible spacer so don't limit your search to shimano - pm180 to pm203 is the same thing no matter who makes it
Eg (possibly)
https://www.uberbikecomponents.com/view-product/Uberbike-Post-to-Post-PM7-180mm-Direct-Mount-to-203mm-Disc-Brake-Adapter-Colour-Options
Posted : 02/05/2021 6:30 pm
Hope 'H' mount will also do the job, that's what I have on my 2021 Pikes.
Posted : 02/05/2021 6:38 pm
Ok, so ive ordered a mount from Uberbike, now unsure on the hardware... Any ideas on bolt length?
Posted : 02/05/2021 8:15 pm
It should come with the correct bolts.
Posted : 03/05/2021 9:15 am
Thats two probs in a row, you'll now need conical washers and longer bolts of two different lengths, bolts not supplied with the uber one, should have gone Hope.
Posted : 03/05/2021 11:49 am
Couldnt find hope in stock. Im not in a blessed position to have 12 bikes in the garage so waiting an unspecified time seemed like a horrible idea.
Posted : 03/05/2021 12:26 pm
Ah sorry didn't spot the lack of bolts with uberbike. I'd just give them a call tomorrow to get the spec then nip to my local bolt emporium, or ebay if necessary - or if uberbike aren't responsive wait until it arrives and see what extra length you need to add at each end.
Posted : 03/05/2021 1:18 pm
Uberbike sell the bolts as well, drop down box for correct size
https://www.uberbikecomponents.com/view-product/Uberbike-180PM-PM-Disc-Brake-Adapter-Titanium-Mount-Bolts-Black
Posted : 03/05/2021 1:25 pm
Thanks @Tracey, didn't spot those yesterday!
Posted : 03/05/2021 1:36 pm
