There i was about to quickly change my gear cables for new Goodridge ones. Took the wrong side off of my Sram x9 shifters. Springs flying everywhere and 5 hours later unable to re-build them. Any advise please.
BF
Here you go as long as you found all the parts that is 😉
http://www.ridemonkey.com/forums/showthread.php?p=3012736#post3012736
Yes I know, I am a star.
I've followed that site. The problem is trying to get the spring reloaded correctly. You need really small fingers!!. Any hints or tips. Will this be a £70 mistake. I thought i had done it but when i tried to change gear it would only move up three and the lever was pressed all the way forward.
Nightmare!!!!
I have a pair of x7 shifters (which I prefer to x9 as they feel a bit tougher and have nice indicator windows) that I might be tempted to sell as other bikes have Shimano and I'm trying to "standardise".
Fixes that problem 🙂
Does a female live with you with little dainty fingers?
Long nose pliers? 🙄
When a customer had done this we fixed it but it took two people at once to hold all the springs and bits and pingfukkits in right - a right pig of a job too.
After 12hours of swearing and red raw fingers i think i've fixed it :D. Just been on a 2 hour blast over the fells and the gears change pretty well. The only issue is when i push the larger lever forward to change gear it should release back slightly to engage another gear charge. It's not, so i have to pull it back slightly with my thumb. I think with all the pushing and pulling i may have lost the tension in the spring. I've rang several shops and all have told me that Sram don't sell that part as a spare. Can anyone point in in the right direction or should i just live with this?/
BF
It's fiddly but do-able. I rebuilt my XO shifter. A guy did the same in the shop where I used to work. We gave the customer a new one and eventually got the original one back together.
I still haven't worked out how you're actually meant to change the cables on X9s without getting into all kinds of trouble
I also haven't worked out wtf SRAM were smoking when they thought that was a good design?? 😡
Had this problem
This may do the trick (please excuse the sound track)
If not there is something that will help on U Tube.
D
step away from the bike. put the hammer down on the floor. 😀
once the springs fly out --your foooked..... i had that scenerio on my hardtail bike, and in the end i got a new gear shifter in the end..lol
As others have said, it's fiddly but very doable. If the lever isn't returning, it could be you've got the large washers/seals wonkey/dirty/in the wrong order. You have to be careful not to trap any or them in the spring when you tighten everything up, and a dash of GT85 helps everything run smoothly. It's difficult to explain but a bit of fiddling normally gets things working again.
There's some good walk throughs on the MTBR forum - that's where I got my info from. The X-9 & X-0 shifters are the same as far as a rebuild's concerned.
ahem, let me re-phrase. i still cant believe you need to take apart £70 shifters to change the cable!
"what were they smoking" still stands though 🙂
for the shifter that isn't spring back you probably just have the end of the spring in the wrong hole inside, take it apart carefully and try again. I made this mistake too, had to pull the other shifter apart v carefully to see how it went back together but figured it out in the end.
I done this the other week shifter was very lazy and not returning even with no cable in so i removed the bottom and then bits flew everywhere.
I did it the complete opposite to the guides though as i found the way the guide describes the coils of the spring can get crossed to easy which in turn rub and cause the problem you have.
I took everything out of the shifter so it was just a shell coiled the spring around the shifter lever then with needle nose pliers hooked it into the the shifter housing.
Now works like a charm 😀
Springs flew out of my X0's when i had 'em & managed to put 'em back ok & worked like new - was a right pain to change cables tho' especially how you need to clip the cable end in to that clip thing (if i remember correctly) - Back on Big S now since bikes with sram were nicked!! 😥
