Numpty question, wh...
[Closed] Numpty question, which way round does a dart spring go in?
As title... Serviced a pair of dart 28's this evening and didn't make note of which way the coil came out. Spring has a black bit on the bottom and blue bit with an o ring on top. Which way up? Technical manual no help shows what I think is the black bit up but found YouTube videos showing it go in either way...
Thanks
Posted : 15/12/2014 12:19 am
the spring itself can go in either way. However, the black plastic piece goes at the bottom of the spring. The blue plastic piece with the black o-ring goes on top of the spring and acts as a water seal, so grease the threads of the crown and the o-ring before you install it. it needs to go in straight or the o-ring will snag and it wont seal properly. Do yourself a favour and back-off the pre-load adjuster, to make getting the topcap back on easier.
That should do ya.
Posted : 15/12/2014 1:29 am
Thanks. Anyone know if it actually matters either way?
Top cap is knackered in this case, doesn't turn at all.
Posted : 15/12/2014 8:42 pm
