I reckon I need to tighten my centrelock disc mount hubs, as theres a bit of forward/backward play when the brakes are applied.
I'm a bit confused as to which tool I require to actually tighten these -
http://www.cyclesportsuk.co.uk/product_info.php?products_id=2678
http://www.chainreactioncycles.com/Models.aspx?ModelID=1056
Both say the same thing to me but are different in both cost and design.
I've got the Planet X Shimano XT reetard 29er wheelset
I've noticed that the rivets on centrelock disks sometime allow a bit of play (even when the centrelock is tight) usually on old and worn-out wheels.
Either tool should work on the fitting, I personally prefer the one without the prong in the middle, more versatile.
Either will fit - the proper shimano one with the long peg part is much better as it won't slip off when you're tightening the lockring.
GB
Many thanks both - much appreciated.
£17 for a lockring tool!!! 😮
Blimey...
I bought a whole bike related toolbox for £18 a year or two ago from Aldi.
Think they used to be about £5 for the lockring tool...
In fact, [url= http://www.merlincycles.co.uk/bicycle-workshop-tools/icetoolz-cassette-tool.html ]here you go...[/url]
